Timing
Old Jan 9, 2012 | 08:04 PM
HoustonGuy's Avatar
HoustonGuy
Timing
Hey yall, 400 stroked engine never had much power since i got it so i finally got the distributor shaft unstuck to set timing...with no timing mark or light but with a vacuum gauge. I got it running good enough to spin tires without going dead. But this morning when I cranked it up it sounded mighty rough and bad. So I rammed the accelerator after it idled for a while and it popped and went dead. Do yall think I need to set idle mixture now that I reset the timing?
Old Jan 9, 2012 | 08:20 PM
HoustonGuy's Avatar
HoustonGuy
or is it something else
Old Jan 9, 2012 | 08:26 PM
2kvert's Avatar
2kvert
Is this electronic or points?
Old Jan 9, 2012 | 08:27 PM
HoustonGuy's Avatar
HoustonGuy
electric, i dont think they used points in '77 but u prolly know more than I do
Old Jan 9, 2012 | 08:41 PM
4xfourdoorFloyd's Avatar
4xfourdoorFloyd
easy way to tell 1.look under hood 2. driver side inner fender there will be a grey box held on by 2 screws. 3. if not sure see local mechanic
Old Jan 10, 2012 | 11:19 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
77 I hope it is solid state. When you cranked it did the starter drag or what? If it drug then it is too advanced. 400s usually had room to advance some from stock, I always set them around 10* and that helped. Advance until it drags starter or until it pings then retard immediately until minimal or no pinging and cranks good.
nlareau
Aug 26, 2011 08:10 AM
mkrog
16
Mar 28, 2011 02:17 PM
bhardy501
May 12, 2007 07:33 PM
bigbore
1978 - 1996 Big Bronco
Mar 4, 2004 11:44 AM
Ratsmoker
May 26, 2002 03:00 PM
