Loose Steering
Old Apr 18, 2003 | 10:04 PM
Hi Ho's Avatar
Hi Ho
Exclamation Loose Steering
How would I tighten the steering in my 1977 F-250 SuperCab? I can move the wheel about 5 degrees before the truck starts turning. When driving it's non-stop correcting because it wanders so much.
Old Apr 18, 2003 | 10:30 PM
Mil1ion's Avatar
Mil1ion
Loose Steering
Go to search > Type in >
Adjusting Power steering " or "Power steering adjustment"
search this forum 73-79 and you should see a least 6 threads with the info.
Old Apr 20, 2003 | 02:12 PM
73Custom's Avatar
73Custom
Loose Steering
Is it a 2wd or 4x4?
Are you sure it needs adjusted or is there a worn part that needs replaced? Have someone rock the steering back and forth while you look over every joint of the steering. Take note of the joint on the column above the steering box, all the tie rods and kingpins/ball joints. If there is any play or looseness, then they need replaced. Worn rubber bushings will cause looseness too - radius arm bushings, axle pivot bushings and spring bushings. Check wheel bearings for looseness too.
If all checks out okay, then you may need to adjust or replace the steering box.
Marty
Old Apr 20, 2003 | 03:49 PM
Torque1st's Avatar
Torque1st
Posting Legend
Loose Steering
5 degrees would be GOOD for many of these old trucks. They just aren't rack & pinion setups.
Old Apr 20, 2003 | 09:10 PM
Gidde Up's Avatar
Gidde Up
Loose Steering
I had the same problem and replaced all the bushings with poly urethane bushings and I had a very responsive steering. It was very easy to do didn't cost much.
Good luck!
Old Apr 20, 2003 | 10:56 PM
Hi Ho's Avatar
Hi Ho
Loose Steering
I tightened the steering and it works great now.
Old Apr 21, 2003 | 02:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
Loose Steering
It will work even better when you get those bushings replaced. It sounds like you need to get that truck into a TRUCK front end shop. The normal car shops don't know how to fix iron vehicles, only the beer can jobs. You can also tighten that adjustment nut toooo much and the steering can bind and wear parts quickly.
Old Apr 21, 2003 | 08:10 PM
Hi Ho's Avatar
Hi Ho
Loose Steering
Yes, I'm planning to do it myself. I was careful not to tighten the nut to much.
Old Apr 22, 2003 | 04:13 AM
Torque1st's Avatar
Torque1st
Posting Legend
Loose Steering
The reason I said take it to a real shop is that those guys have the experience to spot stuff you might overlook. The front end on a truck is a serious safety item.
