HELP! Clutch Fan
Old Jan 8, 2012 | 04:36 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
HELP! Clutch Fan
Anyone have any tips/ tricks for this clutch fan!? I cant get the dang thing loose!
Also, I'm getting to the point in the day where I might not finish the WP replacement by the time its dark. And I need the truck tomorrow. I have about 7 gallons of distilled water. Can I run my truck on distilled water until I get another change to tear into it? Which will be Tuesday.
Old Jan 8, 2012 | 05:17 PM
tdpower's Avatar
tdpower
I rented the fan clutch removal tools from autozone. You should be ok to run it with distilled water as long as it's not going to freeze.
Old Jan 8, 2012 | 05:35 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Doubt it will freeze in SoCal.
I have the tools from AutoZone. I also used a pipe wrench and even the chisel method. NOTHING worked.
Old Jan 8, 2012 | 05:44 PM
Stewart_H's Avatar
Stewart_H
You have the tools from Autozone and they aren't working?
Yes, you can run with just distilled.
Stewart
Old Jan 8, 2012 | 05:55 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
They're on the fan and pulley but I can't get it loose!
Old Jan 8, 2012 | 06:59 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Is it a reverse thread? I think the scientific term is righty loosey lefty tighty.
slim613's Avatar
slim613
dang man didnt u just fix a problem? hope ur able to get this figured out id hold a flashlight and do what ever else i was needed to if i was closer
goodluck bud!!
Old Jan 8, 2012 | 07:10 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Actually these aren't. I thought so too so I looked it up.
Old Jan 8, 2012 | 07:20 PM
F350-6's Avatar
F350-6
I used a wrench from autozoo and then a HUGE crescent wrench on the nut to break one loose. I also think Bill had a great idea when he did his. https://www.ford-trucks.com/forums/1...r-in-pics.html
Be sure to leave him reps for that post.
Old Jan 8, 2012 | 07:27 PM
milleroutdoors's Avatar
milleroutdoors
If you can get a 2nd pair of hands have them hold it from turning and apply pressure with the other tool, hitting it with a hammer. Should pop it loose.
Old Jan 8, 2012 | 07:36 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I love that. I will do that!!
Old Jan 8, 2012 | 09:27 PM
helifixer's Avatar
helifixer
heat it with a torch if previous person put red lock tite on it
old blue 90
Sep 25, 2007 08:33 AM
optikal illushun
Jul 13, 2005 08:37 PM
Will Shestart
Oct 4, 2004 09:13 PM
SmokeBlower
Jun 29, 2004 08:41 PM
Lakeitel
Jul 11, 2003 10:06 PM
