Replacing the fuel pump
Old Jan 8, 2012 | 04:16 PM
Monana ford Man's Avatar
Monana ford Man
I hae a 77 F-250 CS that needs a new fuel pump. Is there anything unusual in the changeout or is it as straight forward as it seems? The arm goes under the lobe correct?
Old Jan 8, 2012 | 04:28 PM
fmc400's Avatar
fmc400
MSEE
That's correct, arm under the eccentric. Turn the engine over to TDC before you start the job; this will move the eccentric all the way up and take the pressure off the arm. Use only a flare wrench to disconnect and reconnect the output line.
colesrock
Jul 24, 2015 02:01 AM
mickk35
May 13, 2015 12:40 PM
JoeHarbourJets
Aug 21, 2011 09:08 AM
mfeveleth
May 17, 2011 10:23 PM
Old93junk
Illinois Chapter
May 11, 2009 06:38 PM
