460 head ?
Old Jan 7, 2012 | 08:19 PM
miottimouse's Avatar
miottimouse
460 head ?
good day would any one have an accurate weight on a 460 iron head? looking to get 1 set shipped and an estemate thanks
Old Jan 7, 2012 | 09:22 PM
jgavac's Avatar
jgavac
IIRC a D3VE head would be about 72 lbs.
Old Jan 8, 2012 | 05:48 AM
miottimouse
ok thank you hey i just noticed you have a 72 lincoln with d3 non smog heads in your avatar? is every thing the same on these heads [compression,front accessory bolt holes,intake,exaust bolt holes the same as later d3s ? minus the 1 bolt fitting on the back of the head? as these heads i am looking to by came of a 73 and i dont see any smog holes in the pics he sent me mentioned thanks
Old Jan 8, 2012 | 06:45 PM
jgavac's Avatar
jgavac
Front accessory bolt holes and intake/exhaust holes are the same. As far as compression, there might be a difference between mine and whatever year yours is, based on smog regulations. The combustion chambers are the same size (93cc), but there still might be a difference in comp, because later year 460's had very low compression
Rovernut
May 14, 2018 06:24 AM
Andrew LowKeySun
Apr 28, 2016 11:21 PM
Ken(Ark)
Flathead V8 & Flathead 6
Jun 9, 2012 10:30 AM
DriveFords4Life
Sep 22, 2007 02:02 AM
asigalet
Jul 29, 2005 06:20 AM
