fuel pump installation
Old May 16, 2011 | 10:17 PM
mfeveleth's Avatar
mfeveleth
1978 F250 with a 460
First thanks for the help with my turn signal wiring harness.
Now I am having one heck of a time getting the new fuel pump in and so I am wondering if there is a trick to compressing and holding the arm or getting the cam in a position where the arm does not need to be compressed so much.
I have tried to compress and get a bolt started but it's not working any help will be appreciated.
Old May 16, 2011 | 10:40 PM
montana_highboy's Avatar
montana_highboy
It really shouldn't be fighting you that much, you are installing the pump arm under the cam eccentric and not above it correct?
Old May 16, 2011 | 10:45 PM
mfeveleth's Avatar
mfeveleth
I believe so. The bolts just won't line up with the holes.
Old May 16, 2011 | 10:51 PM
montana_highboy
This generally isn't required, but if you want you can bump the motor over until the cam eccentric puts less pressure on the pump arm.
Old May 17, 2011 | 07:17 AM
fmc400's Avatar
fmc400
MSEE
Try turning the motor over to TDC and then put in the pump.
Old May 17, 2011 | 09:28 AM
Thunderbird7480's Avatar
Thunderbird7480
+1. Blip the starter. Might have to do it more than once to get it right. Also, check your engine code. Is it the original engine? My 460 in my '77 is out of a '70 Lincoln and has a different fuel pump. Most of the time I can order parts for mine with just the make and model of the truck. Fuel pump is different though.
Old May 17, 2011 | 09:39 AM
LedheadELH's Avatar
LedheadELH
Fuel pump may be different. Depends on the the motor was originally in. Sometimes they used a pump that went up, instead of down for more clearance for powersteering pump maybe?? either way, the motor is the same just different pump. This may be something to at least look into
Old May 17, 2011 | 10:23 PM
mfeveleth's Avatar
mfeveleth
Well all it took was to rotate the engine a little and she went right in. I should have thought about that since I figured it ran off the cam.
Thanks a lot!
