Sponsored by: Kumho
2000 Ranger upper ball joint replacement?
Old Jan 8, 2012 | 01:54 PM
Guest user's Avatar
Guest user
Hello,
I have a 2000 Ranger 2x4 that needs ball joints, and I need opinions on how to proceed.
Apparently, the uppers can either be replaced by pressing in a new one, or by replacing the complete upper control arm.
I could really use some information about the pros and cons of reusing the upper control arm.
And, will reusing the control arm require the use of a 50 ton press?
Thanks for any help or information.
Old Jan 8, 2012 | 02:36 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/1...ll-joints.html Click on this link and have a read through the posts, including the last one.
Old Jan 8, 2012 | 11:30 PM
Guest user's Avatar
Guest user
Thanks for the reply.
I had read that thread earlier, and although informative, it is lacking information on whether replacing the upper ball joint without replacing the UCA is a good idea.
What I'm wondering is if anyone has ever had an upper ball joint that was pressed into an old UCA come out. The practice of reusing a control arm without any way of retaining the ball joint is new to me. I guess that I'm a little skeptical about the control arms ability to secure a new ball joint into a hole that had the same sized part removed. It would seem that the hole would be left somewhat enlarged from having been used.
This is not like replacing a wheel bearing where the part that was previously expanded(the bearing) is being replaced, if you know what I mean.
Thanks for the help, but I think I just convinced myself that buying a new control arm is the correct way to proceed.
oops
1983 - 2012 Ranger & B-Series
Apr 16, 2010 04:59 PM
643NRK
Dec 7, 2007 11:21 AM
eigenvector
Nov 10, 2006 09:05 PM
FTE Ken
Nov 23, 2002 06:46 PM
