Front return line on passengers side ?
Old Jan 8, 2012 | 12:16 PM
DanCampbell's Avatar
DanCampbell
All
Im changing the O rings and caps for the return lines and the front one (front of truck)on the passengers side has a riser or bolt under it that is different than the others.
I'm not sure if it comes off as two peaces
When I put the wrench on the return line nut the whole thing started to move.
Can someone help me out?
Thanks
Dan
Old Jan 8, 2012 | 03:41 PM
Crazy2's Avatar
Crazy2
yes take the line off then side plastic peace off then on do that fitting then you can get at the return line cap
Old Jan 8, 2012 | 04:32 PM
greywynd's Avatar
greywynd
Make sure you put that piece back in too, as it will affect the timing on the #1 cylinder without it. That is a timing adapter that was added on the 7.3's.
Old Jan 8, 2012 | 07:01 PM
DanCampbell
Thanks guys.
OK,
This is the way it was set up on mine.
From top
Return line fitting
Brass nut / fitting (was not on any of the others)
Is that the timing adapter?
Under that fitting was the plastic return line cap that I replaced.
It's all done and back together now, but I can't start the truck because my batteries are drained...very slow cranks. Must have been from trying to start it forever before I changed the glow plugs..
Dan
Old Jan 8, 2012 | 08:31 PM
greywynd's Avatar
greywynd
The top most 'nut' for the steel line is the injector line. Next down is the timing adapter, then under that is the plastic return line 'tee'.
Old Jan 9, 2012 | 04:24 AM
PLC7.3's Avatar
PLC7.3
FYI the #1 injector line on the Eseries (van) can replace the Fseries line with the timing adapter installed. The Eseries uses #4 for the timing, so their #1 is the correct length without the adapter should you wish to change it.
Old Jan 9, 2012 | 08:17 AM
DanCampbell
Thanks guys
1989f250IDI
Apr 4, 2013 11:01 PM
SuperSnake
North Carolina Chapter
Aug 30, 2006 06:44 PM
bedardrob
16
Aug 18, 2005 11:04 PM
jberylecrider
Offroad & 4x4
Aug 19, 2002 10:22 PM
