fast idle
Old Jan 7, 2012 | 10:29 PM
rdwhusker's Avatar
rdwhusker
fast idle
I have a 90 truck150 with a 5.0 that idles at 2000 rpms when it warmup. replaced the iac did not help. any more ideas?
Old Jan 9, 2012 | 01:47 PM
dwester's Avatar
dwester
Try checking the TPS or you might have a leak some where, also check ground conections and look for corrosion.
Old Jan 9, 2012 | 04:19 PM
mpc07005's Avatar
mpc07005
Did you check that number with a dwell/tach? Tachs can be 400~1000 rpm off easy. Was it cold out (High idle to warm up? It is winter.)?
-Mike
Old Jan 9, 2012 | 06:28 PM
88n94's Avatar
88n94
I'm working on that very problem now with my '94 F-150 with a 351. I think i get it narrowed down to either the throttle position sensor or the coolant temperature sensor. I'm really thinking it's the coolant temperature sensor. I ordered a throttle position sensor from Ford anyway, going to put it in when i clean the throttle body. I will try one part at a time so I know what the problem was. If I get it fixed that is.
If I was to guess on yours, I would say coolant temperature sensor. I was just looking on rockauto.com parts site and they gave an explanation of what the coolant temperature sensor will do when bad. Look up coolant temperature sensor and they list the different brands of said part and click on more info. I think this explanation was listed under one of the Standard brand coolant temperature sensors. I'll try to remember to keep updated, may be a few days. Good luck with your truck.
Old Jan 10, 2012 | 06:50 PM
88n94's Avatar
88n94
Update to my reply last night under No. 4. I cleaned the throttle body and replaced the throttle position sensor while I had the throttle body off. It would have been impossible to replace the throttle position sensor without unbolting the throttle body. Low and behold my high idle problem is GONE. I can't see how a dirty throttle body would cause a fast idle, although the throttle body was really grimy. So a bad throttle position sensor must have been my problem.
Old Jan 10, 2012 | 07:55 PM
Jlckb5's Avatar
Jlckb5
My 89 was doing the same thing. Cleaned the throttle body and the problem is gone so far.
Old Jan 10, 2012 | 08:53 PM
mpc07005's Avatar
mpc07005
... we still don't know if there even is a high idle problem. OP hasn't been on since the morning after making the thread.
-Mike
Old Jan 10, 2012 | 10:08 PM
rdwhusker's Avatar
rdwhusker
high idle
It is a fast idle. I am going to try the collant sensor this weekend. the idle air control did not help. thanks for the help
Old Jan 10, 2012 | 11:06 PM
88n94's Avatar
88n94
The Haynes repair manual gives a lot of information on testing the different sensors and even what codes point to which sensor is bad. But I guess I don't have the patience to read all that. I was so sure that the throttle position sensor wouldn't fix my fast idle that I ordered a coolant temperature sensor when I picked up the TPS.
Old Jan 11, 2012 | 06:34 AM
cjben's Avatar
cjben
Does the idle stay high or is it just high for about 30 seconds after a cold start up,and then idle down to normal idle? my 95 does this and it is normal.
Old Jan 11, 2012 | 06:55 AM
mpc07005's Avatar
mpc07005
So you confirmed your tach with a dwell/tach meter and it was over ~50-60 degrees out?(putting in your location causes us to leave out questions like that.)
-Mike
duback66
Jun 29, 2011 04:42 PM
Pitchfork87
Dec 24, 2010 05:35 AM
moebdick
Oct 4, 2010 05:06 PM
tomucen
Aerostar
Jan 8, 2002 10:11 AM
