Which ballast resistor?
Old Jan 7, 2012 | 08:01 PM
reed1951's Avatar
reed1951
Hey guys, I bought an 85 mustang distributor, an "accel" coil, stock 85 mustang ignition module, stock starter solenoid....but I need a ballast resistor. Which ballast resistor do you guys recommend? All I seem to find are aftermarket resisters and don't know which to choose. I converted this engine from EFI to carb and everyone recommended to go the duraspark II route.
Old Jan 7, 2012 | 08:49 PM
Ken(Ark)'s Avatar
Ken(Ark)
Originally Posted by reed1951
Hey guys, I bought an 85 mustang distributor, an "accel" coil, stock 85 mustang ignition module,...... Which ballast resistor do you guys recommend? .
We get into this a lot on the flathead Ford tractors when converting to 12v .
Each type of coil needs a certain numbers of ohms resistance in ratio to the voltage . The coil resistance has nothing to do with the rest of the ignition system . A 6v coil will work in a 12v system if you have enough ohms resistance . Too much and you have a weak spark , too little and you fry the coil eventually .
Best bet would be to go to "Accel's" web site and use the recommendations for their coil .
One neat thing about the resistors is when you first power the coil it is getting the full voltage and a hotter spark to start the motor . Shortly after the resistor starts working and drops the power to the coil , keeping it from overheating .
Old Jan 8, 2012 | 09:48 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Stock resistor for 76-82 DSll is 1.1 ohms. For 85 I believe the TFI coil was used, and out of my knowledge base. As Ken posted, refer to manufacturer for whats recommended for which coil.
captntim
May 3, 2024 12:36 PM
peka
34
May 20, 2015 01:20 PM
Delta Dirt
Aug 26, 2013 08:56 PM
dangolbadangdang
Oct 11, 2011 07:16 PM
Pony Power
Electrical Systems/Wiring
Jul 27, 2006 09:43 PM
