Need Help! 400M
Old Jan 7, 2012 | 01:37 PM
finneys98xj's Avatar
finneys98xj
Need Help! 400M
Ok I got the truck running after the cam and lifters and timing now here is the new problem. The drivers side lifter aren't pumping like they suppose too. The first lifter on the third cylinder on the driver side is squirting oil like you would'nt belive. all others are pumping but not like they should.
Why would that one pump like hell but not the others? New push rods/cam/lifters. COmp cam 260.
Old Jan 7, 2012 | 02:35 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I have very little hands on expertise with overjauling 400s but I would guess there might be an obstruction in the oil gallery in the cam journals. I have a manual I can look at and see where the oil goes from the lifters. It looks like maybe the oil goes from the mains to the cam bearings, then from the cam bearings to the lifters then ?maybe? drains out the lifters on the end of the block to relieve pressure. I am no expert but I would look into an obstruction in the gallery. Good luck
Wallingnuma
31
Nov 19, 2012 05:51 AM
father/son
Apr 19, 2007 01:14 PM
likethefords
Apr 5, 2007 12:49 PM
pkulaga
Sep 4, 2005 08:16 PM
jeffbran
16
Apr 23, 2004 01:07 PM
