Fuel leaks
Old Jan 6, 2012 | 11:37 PM
Ford_Six's Avatar
Ford_Six
Fuel leaks
My "new" engine sat in storage for a little over a year before I could install it. Now that it's been running for a week, a few leaks have developed.
A couple are easy to fix (fuel heater leaking out of plug, delete fuel heater; injector return o-rings) but one is a cause of some concern:
The valley pan is wet, and it seems to be coming from the injection pump. Some of it is from a leaking fitting on the filter-pump line, but there also seems to be some fuel coming from the advance cam actuating arm fitting down at the bottom. Is this something that can be resealed, or is it an indication of a larger problem?
Old Jan 8, 2012 | 02:18 PM
Ford_Six's Avatar
Ford_Six
Anyone know if this can be resealed?
Old Jan 8, 2012 | 02:22 PM
rmalottwtes30's Avatar
rmalottwtes30
Can you get a picture of where its leaking? Is it a small leak or something major?
Old Jan 8, 2012 | 04:35 PM
greywynd's Avatar
greywynd
A diesel shop should be able to reseal the pump, but the issue will be what caused the leak? Is it simply a seal dried out, aged sort of thing, or is it wear. If it's worn on the shaft then it may need more work.
Not likely the sort of thing that you can redo yourself easily though.
imjwm
Jun 21, 2014 10:47 PM
Tomahak
Dec 9, 2012 11:33 AM
Powerstroker96
Mar 8, 2008 12:05 PM
2 stroke man
24
Mar 3, 2008 10:45 AM
fortlangley7.3l
Jun 19, 2006 10:15 AM
