yes i have tried about 10 of them. got one in the truck now from a boneyard that has no drive. i dont want to roll the dice again. thanks for your wise suggestion.
If you have tried 10 different E4OD's and none of them have worked I doubt it was a bad transmission to start with..
E4OD is completely computer controlled, and if the computer ain't happy the E4OD ain't working! Simple as that..
Simple things like TPS sensors, VSS sensors, multifunction switches (neutral safety) bad wiring on the solenoid pack and a host of other electrical problems can all cause it to not operate at all or in best case operate poorly..
no not 15 trannys. 15 bone yards. sorry for the confusion on that guys. i am getting a 625 code but another guy on here said he didnt think it was my problem.hell i dont no much about trannys. i got everything but drive. really gettin to be discouraging. i live in the milwaukee wisconsin area. between milwaukee and chicago.
No trans expert here but that might be the issue,
625 Electronic Pressure Control driver open in EEC
That is a KOEO and or CM test result.
Its not having enough pressure or pressure in the right place/time to shift to drive?
None of you new mEmbers have enough posts to have a signature, but it would be helpful for you to put in a location in your profile so it shows up in the upper rt corner of your posts. That way people know where you are and can offer help in person.
lol. dont know if im brave enough to try that. thanks for the info. from a crappy little town called kenosha wisconsin. i guess ill learn the ins and outs of this forum as i go. sorry. thanks guys.
