windshield washer pump
Old Jan 5, 2012 | 06:26 PM
1997fordf350's Avatar
1997fordf350
hi I was wondering on how to take out a windshield washer pump off of a 1997 ford f350 with a 7.5 in it?
Old Jan 5, 2012 | 09:07 PM
GoinBoarding's Avatar
GoinBoarding
I'd imagine its the same as a 96' F-150, though I may be wrong.
You'll need to remove the coolant overflow/washer fluid resovior. There is a wire connector underneath or just off to the side for the pump itself. Disconnect that. Drain the coolant from the overflow. Unbolt the resovior, remove both the coolant hose and the washer fluid hose, and remove from engine bay.
There is a thin ring that slides in one way but fights coming back out that holds the pump in place. This is located on the bottom of the plastic tank/resovior. I used a flat blade screwdriver to bend that ring then pulled it out with a needle nose pliers. Now the pump simply slides out. A new pump will include a new retainer ring. Installation is the reverse of these steps. Add fluids and enjoy the visibility.
brfan
Jul 21, 2018 11:21 PM
Dean06919
Jul 12, 2015 09:17 PM
spaytons
Apr 12, 2014 08:46 PM
1980302windsor
Jan 18, 2012 01:36 PM
royzell
Electrical Systems/Wiring
Nov 28, 2007 03:56 PM
