Need Help with tire load range numbers.
Old Jan 30, 2012 | 08:23 AM
pcg7849's Avatar
pcg7849
If the stock rim is at least 9 inches wide you should be fine. If it is narrower then I would not recommend it.
Old Mar 31, 2012 | 01:11 PM
LWW's Avatar
LWW
Originally Posted by Jayybird
Will the 12.50's fit on a stock rim?
Yes, you can make anything fit. Should you? No, the stock wheel is only 8" wide and is not recommended for a 12.5" wide tire.
airjeff
Jan 24, 2011 01:04 PM
jefftb
All Things Towing
Jul 6, 2008 11:36 AM
1978fordf250
May 17, 2006 12:26 PM
foxracer800
Mar 12, 2006 09:02 AM
celrifai
Aftermarket Products
Sep 22, 2003 06:21 PM
