Duraspark help
Old Jan 5, 2012 | 11:29 AM
Saltine01's Avatar
Saltine01
Duraspark help
Swapped and 83' 351w into 89 bronco kept carb. and wired up duraspark system, vehicle will only run with the key in the start position. any ideas?
Old Jan 5, 2012 | 01:24 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Check voltage to module. Battery voltage to red in run and white in start. See if you're getting voltage to plus side of coil in run position.
Old Jan 5, 2012 | 09:44 PM
Saltine01's Avatar
Saltine01
Pretty sure i found the problem. Found no power going to coil in run from switch, checked resistance wire going from run to start circuits. found wire had 34 ohms resistance (way to much according to diagram) i made the wire using a 1.06 ohm resistor and soldered it to some wires. i just used a normal resistor will it not handle the current im putting through it? was just thinking about calling the local scrap yard and having them cut a resistance wire out of an old truck?
Old Jan 6, 2012 | 07:17 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Ceramic ballast resistors can be found at NAPA, just mount to firewall. 1.1 ohms for a DSII is perfect, though .8 to 1.4 is acceptable.
Old Jan 6, 2012 | 07:38 AM
Saltine01's Avatar
Saltine01
ok will check around local parts stores for resitors, hopfully someone has something around here really want to get this thing runnin'
Old Jan 6, 2012 | 08:39 AM
Saltine01's Avatar
Saltine01
Alright just got back for the auto parts store. the only thing they had is a 1.2 ohm resistor though that should be close enough will wire it up here today to see if it works had a hard night of b-day drinking and not feeling too good this morning......
Old Jan 6, 2012 | 06:48 PM
Franklin2's Avatar
Franklin2
Mount the resistor out in the open where it will stay cool. They do heat up while the engine is running.
Old Jan 7, 2012 | 03:33 PM
Saltine01's Avatar
Saltine01
got an resistor the best i could get is a 1.35 ohm. now next problem is i used the s circuit of the starter for my hot in start wire for my duraspark so it backfeeds power to starter while key is in run so now i have to rewire that.......eventually i get it right lol
Old Jan 7, 2012 | 04:33 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Your power feed for the Duraspark module should always go back to the ignition switch. Short cuts only confuse matters.
Old Jan 10, 2012 | 10:04 AM
Saltine01's Avatar
Saltine01
ended up running wire right off ignition like i originally should have. tried it out and old truck started right up and purred like a kitten
Old Jan 10, 2012 | 03:31 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Very good. Thanks for following up on results.
Old Jan 11, 2012 | 12:32 PM
Saltine01's Avatar
Saltine01
yea one part of my build process done, trying to make this into a mud truck but i have alot of work to go.
Pinzer
Electrical Systems/Wiring
18
Jan 19, 2016 11:13 PM
78 Ford F150 460
38
Jul 28, 2015 07:51 AM
jdmports22
Feb 7, 2014 08:39 AM
marspenc
Jul 10, 2006 10:25 AM
apollos
1978 - 1996 Big Bronco
Aug 2, 2003 05:27 PM
