Your best bet is go with a dually and 22.5 Semi tires - its tight but I believe the 37"s fit - tall and narrow! Not quite what your looking for I know.
Man, you guys got me concerned. I am in the middle of a 4.5 lift,bilsten remote res shocks, double fox steering stabilizers. I am installing American force 22s with 37x13.5 nittos, per American, 4.5 lift will work with possible bumper bracket modification. Hopefully I have no issues.
You should be fine Kevin I have 35/12.50/20 On mine with a 2 1/2 level lift with no rubbing anywhere not even close. I did do a 4" block to lift the rear it sits pretty level from the factory.
Ok I just finished the install of my 2.5" on my 2012 f250 ! All went fairly smooth but I have one question ! W the spacers installed it seems like the coil springs are bowing in the center a little ! Is that normal or did I screw up somewhere ?
I am getting ready to do a similar setup. How did it go for you?
I look at the lift threads all the time because I too want to lift mine a some point here when I get caught up on all the other stuff I got going on. In a number of threads I have noticed that some guys with the same lifts and tires say they rub and some say they don't. For me, any rubbing doesn't work. Been there done that before. So my question is, could the rubs be from not quite having the right wheel offset"s?
When I lift/level I just want to do it right and any tire purchases in the future I want to make sure there isn't any rubbing.
