Wow! Your asking alot out of stock wheels and no lift. I have the 4.5 inch ICON lift and the 37's contacted the front bumper bracket. I guess a 2.5 inch leveling kit will get you close but there will be contact issues.
Thanks for the replys guys. I like the stuffed look and was wondering if it was possible since 35's fit without a lift. I realize you will have rubbing on the control arms either way due to stock wheel's offset. 6.7Fan, do you have any pics from the side by any chance?
Did u have to get a rear block with your 2.5" leveling kit ? I have a 2012 and want to get a leveling kit but my local dealer says w the 2.5 kit areas block is needed or it will be nose up !
If you have an F250, then a 2.5" will need block out in the rear. If you have an F250 and want level, then you will need a 1.5" level kit up front.
If you have an F350, then 2.5" will get you level.
