Pics of trucks with 37's
Old 01-18-2012, 03:29 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Originally Posted by Tom-teezy !
Thanks ! I went thru my local dealer and they dnt sell ready lift so I have to get u bolts separate !
No prob. Make sure to post up pics...when all complete!
biz
Old 01-18-2012, 03:38 PM
Tom-teezy !'s Avatar
Tom-teezy !
Tom-teezy ! is offline
Will do for sure !
Old 01-18-2012, 03:46 PM
Sportscraft's Avatar
Sportscraft
Sportscraft is offline
Your best bet is go with a dually and 22.5 Semi tires - its tight but I believe the 37"s fit - tall and narrow! Not quite what your looking for I know.
Old 01-18-2012, 06:57 PM
Kevin9160's Avatar
Kevin9160
Kevin9160 is offline
In process of installing 37 nittos
Man, you guys got me concerned. I am in the middle of a 4.5 lift,bilsten remote res shocks, double fox steering stabilizers. I am installing American force 22s with 37x13.5 nittos, per American, 4.5 lift will work with possible bumper bracket modification. Hopefully I have no issues.
Old 01-18-2012, 08:43 PM
farmerdave's Avatar
farmerdave
farmerdave is offline
Kevin- it's going to be close. Post pics!
250 or 350? A little sheet metal trimming is ok. Don't worry
Old 01-18-2012, 10:52 PM
maxxoffroad's Avatar
maxxoffroad
maxxoffroad is offline
You should be fine Kevin I have 35/12.50/20 On mine with a 2 1/2 level lift with no rubbing anywhere not even close. I did do a 4" block to lift the rear it sits pretty level from the factory.
Old 01-18-2012, 11:14 PM
Tom-teezy !
Ok I just finished the install of my 2.5" on my 2012 f250 ! All went fairly smooth but I have one question ! W the spacers installed it seems like the coil springs are bowing in the center a little ! Is that normal or did I screw up somewhere ?
Old 12-29-2015, 11:01 PM
aus10_c's Avatar
aus10_c
aus10_c is offline
I am getting ready to do a similar setup. How did it go for you?
Old 12-30-2015, 09:14 AM
bkuuz1's Avatar
bkuuz1
bkuuz1 is offline
I look at the lift threads all the time because I too want to lift mine a some point here when I get caught up on all the other stuff I got going on. In a number of threads I have noticed that some guys with the same lifts and tires say they rub and some say they don't. For me, any rubbing doesn't work. Been there done that before. So my question is, could the rubs be from not quite having the right wheel offset"s?
When I lift/level I just want to do it right and any tire purchases in the future I want to make sure there isn't any rubbing.
Thanks for all the help.
Old 12-30-2015, 03:17 PM
motocaptain's Avatar
motocaptain
motocaptain is offline
Old 01-05-2016, 10:30 AM
89LX306's Avatar
89LX306
89LX306 is offline
Good looking truck motocaptain.
Here is my '12 leveled with 37x13.5x20 Toyo RT's. It does rub on the radius arms, but so did my 315/60/20 Toyo MT's.
Old 01-12-2016, 06:29 PM
93-331-29PSI's Avatar
93-331-29PSI
93-331-29PSI is offline
Originally Posted by motocaptain
Nice looking truck!! What wheels are you running? Offset?
  #28
Old 01-13-2016, 01:54 AM
motocaptain
Walker Evans Racing wheels , 17x9 with 37's , I believe they are 5.5 backspace
nico963
2017+ Super Duty
12-20-2018 10:32 PM
Crazy4x4
2004 - 2008 F150
03-29-2014 08:20 AM
LONG EL
06-01-2010 01:51 PM
mj8
2004 - 2008 F150
02-28-2006 07:48 PM
CBSuperduty
1999 to 2016 Super Duty
06-24-2002 07:52 PM
Quick Reply: Pics of trucks with 37's
