turbo cleaning ?
Old Jan 4, 2012 | 08:42 PM
freedomfarmer's Avatar
freedomfarmer
turbo cleaning ?
I have the turbo out and has about 50k on it remand unit replaced under warranty . Should I open it up and have a look and clean or am I better leaving it alone?
Old Jan 4, 2012 | 09:01 PM
Dieselpop's Avatar
Dieselpop
If you think you were having turbo problems low boost over boost clean it do you run cetane in the fuel, helps to keep it clean
DTS Articles - Turbocharger Reconditioning
parts if needed
4C4Z-9V424-AA Turbo cleaning kit
pop
Old Jan 4, 2012 | 09:02 PM
BobbyB's Avatar
BobbyB
That's a tough question, but I believe I would clean it. You wont need any additional parts, you need the turbo hardware kit anyway. All you need is some high temp nickel anti-seize.
Take your time and its really not that hard to clean. Plus you will have the piece of mind knowing that you have a nice clean turbo.
Old Jan 5, 2012 | 06:15 AM
freedomfarmer
Don't believe any trouble just had to take it out for other repairs.
Old Jan 5, 2012 | 07:23 AM
sammy77's Avatar
sammy77
If it's out, I'd clean it.
Old Jan 5, 2012 | 08:51 AM
High Binder's Avatar
High Binder
I'd clean it. You just need a die grinder with a rough pad which you can get from Home Depot or the like for cheap, A Dremel with a wire brush would work too but would take a little longer. Either way, it's easy and doesn't take more than an hour from start to finish.
cookingguy
Dec 11, 2016 12:47 PM
xaviar
May 12, 2014 06:12 AM
jetact
Sep 9, 2010 10:44 PM
1978fordf250
Jul 2, 2006 11:40 PM
