Powerstroke Not Starting
Old Apr 18, 2003 | 11:04 AM
The Grinch's Avatar
The Grinch
Unhappy Powerstroke Not Starting
I have a 1995 F-250HD with the 7.3 Powerstroke. It will not start. I have replaced the Glowplug relay. I checked the voltage over it and realized it is not getting the signal to send power to the glow plugs. The "wait to start" light does not even come on. Is this a PCM problem? Anyone with a similar prob? I don't want to have to tow the truck to the dealer again!
Old Apr 18, 2003 | 08:17 PM
gcduece's Avatar
gcduece
I'll bite. Have you checked the #22 fuse under the hood? could be the fuel heater shorted out and blown fuse. Do you have tach movement when you try to start? Good luck. duece
Old Apr 19, 2003 | 08:41 PM
The Grinch's Avatar
The Grinch
There is no Tach movement. Does that mean it is the fuse? I have checked all the fuses but I will look again. The local dealer, Valley Ford in Valleyview, Ohio said it could be corrosion, to chase wires and check the grounds. I will hope for a fuse!
Old Apr 20, 2003 | 08:24 AM
powerstroker250's Avatar
powerstroker250
No tach movement usually is indicative the cam position sensor is bad.
Les
Old Apr 20, 2003 | 09:00 AM
gcduece's Avatar
gcduece
Powerstroker is right, no tach movement usually is a bad cps. If you can, get it from international you will save about half.
Old Apr 20, 2003 | 09:57 AM
gseeders's Avatar
gseeders
just wondering if you check your batteries? are they fully charged? What voltage are they while trying to start? If thay drop below 9 volts thay are on the way out. Yes you could have a fuse blown recheck fuses inside cabin and engine compartment.
good luck
over and out
gseeders
Old Apr 20, 2003 | 01:18 PM
The Grinch's Avatar
The Grinch
Batteries are good. Dual Optimas with a battery tender to keep charged. Just put a new CPS on 6 months ago. Ran fine until this problem.
Old Apr 20, 2003 | 02:35 PM
The Grinch's Avatar
The Grinch
Thanks Deuce. Went back and checked the fuse #22 in the engine bay and it was blown. Couldn't see it unless I pulled it! New fuse and the truck runs like it always had, great!
Thanks again.
Grinch
Old Apr 20, 2003 | 08:27 PM
gcduece's Avatar
gcduece
Grinch, you might want to check your fuel heater cause it is probably goin south. Glad to be of help. duece
Old May 5, 2003 | 11:01 AM
The Grinch's Avatar
The Grinch
What indications show the fuel heater is going south??
Old May 5, 2003 | 05:39 PM
gcduece's Avatar
gcduece
usually when you blow fuse 22 it means the fuel heater has shorted out. when you remove the fuel filter you should be able to see the connections on the heater and if they are off then you might want to replace it.
trevorrules
23
Mar 26, 2015 12:10 PM
powerstroke586
Oct 8, 2008 08:53 AM
Vinford
May 12, 2007 01:30 PM
deetown
Mar 22, 2007 12:44 PM
gioval
Jun 14, 2004 03:58 AM
