Sponsored by: Real Truck
air bags ?
Old Jan 4, 2012 | 03:52 PM
ford country boy's Avatar
ford country boy
Question air bags ?
i have an f 250 sd with rear airbags and i want to do a 4 in lift but i was wondering if this clashes with the airbags. i would love to lift it and keep the airbags they really help with loads. the airbags do not have an onboard compressor but i dont think that matters. i just want to know what i have to do before i drop 800 bucks into a lift.
Old Jan 4, 2012 | 04:39 PM
mwsF250's Avatar
mwsF250
Totally doable.
The best way is to use taller airbags (triple bellow) so that you also get a lot more wheel travel, but far and away the most common method is to just put a spacer between one end of the airbag and whatever it's mounted to. Start by checking the website of the manufacturer of your airbags. They should have mounts.
The Firestone set I used came with adjustable brackets between the axle and bottom airbag mount. Not sure if they would have worked for 4", but definitely as much as 3".
Old Jan 4, 2012 | 07:22 PM
AirLiftCompany's Avatar
AirLiftCompany
SPONSOR
We offer a lock n lift spacer just for your situation. We offer 2, 4, and 6" options.
I'm not 100% on whether or not these are compatible with Firestone airbags. If that is what you have I can try to get a definite answer.
If you are interested in purchasing them I would suggest you compare prices of our retailers.
Old Jan 4, 2012 | 08:33 PM
Firefighter 1406's Avatar
Firefighter 1406
I do remember when I ordered my firestones there was a kit that was for a 4" lift. Check out there website.
Old Jan 4, 2012 | 11:18 PM
screwxtr's Avatar
screwxtr
What about if you swap 350 blocks on a 250? Looking to put airbags on my 2011 F250, but I have the 350 blocks.
Old Jan 5, 2012 | 05:43 AM
2011SD's Avatar
2011SD
DO NOT use lock and lift spacers. I went through 3 sets of them on my 06 Dodge Power Wagon the tabs that lock them together kept breaking. I ended up using steel spacers from Tuff Country and they worked 100% better. They come in a range of different sizes from 2in all the way up to 8in.
Old Jan 5, 2012 | 07:02 AM
AirLiftCompany
SPONSOR
I apologize for the troubles you had with our product. I will forward this information onto our design group. Hopefully they can take your experience and at least improve the product for future customers.
Old Jan 5, 2012 | 04:04 PM
ford country boy
i do have firestones so i will have to look into the official kit. so i will have to look into that. i probly wont do it til spring anyway to cold to work outside. thanks for the info.
Old Jan 5, 2012 | 06:50 PM
AirLiftCompany
SPONSOR
I was able to find information on the bolt pattern for Firestone's air bag. As I believed they do have the same bolt spacing for the bottom, the bolt holes are 2.75" apart on our bags and theirs.
Just wanted to let you know what I found out.
Old Jan 5, 2012 | 07:09 PM
Hotpocket's Avatar
Hotpocket
I am also curious on this subject. I put 5 in blocks on my f250 and i would love to get air bags some day.
Old Jan 5, 2012 | 08:47 PM
spinella's Avatar
spinella
nice to see a sponsor helping out. reps to you.
Old Jan 6, 2012 | 12:35 AM
GregsSD's Avatar
GregsSD
If you get the airbags that mount on top of your leaf springs and mount to the outside of the framerails then it won't matter what size blocks you have because the spring is still in the same position!
Old Jan 6, 2012 | 12:56 AM
GregsSD's Avatar
GregsSD
Look at the Firestone Ride-Rites, they have them avaliable that are adjustable to fit either f-250 or F-350's.
I have a set on my truck and they work great!!!
frdf250
30
Feb 22, 2011 07:18 PM
lovestrucks
Nov 9, 2009 10:55 PM
landcruzr
Dec 18, 2008 11:14 AM
lpbaca
Mar 19, 2007 05:49 PM
Brymstone
Jul 18, 2003 05:54 PM
