f250 troubles
Old Jan 3, 2012 | 10:01 PM
Ole' gray's Avatar
Ole' gray
f250 troubles
My truck is a 1990 with a 351, i know its old, and i knew it was going to have issues, but not one as strange as this. Every time it rains, my truck will run like total crap, it boggs horribly, and feels like it has 1/8th of the power it normally has but only for about 20 minutes after starting it. This is even if it rains, and i drive it days later in the summer where any water should have evaporated. What in the world could be causing this?
Old Jan 4, 2012 | 06:46 AM
Lazy K's Avatar
Lazy K
Well, if it was mine, the first thing I would do is fit a new distributor cap, rotor and a decent set of new spark plug wires.
Old Jan 4, 2012 | 07:32 AM
White 97 xlt's Avatar
White 97 xlt
^^ What he said ^^
Old Jan 4, 2012 | 02:41 PM
Ole' gray's Avatar
Ole' gray
its got new plugs and wires, but ill look into getting a new distributor
Old Jan 4, 2012 | 03:09 PM
SCRebel's Avatar
SCRebel
You shouldn't need a distributor. Just the cap and button
Old Jan 4, 2012 | 03:14 PM
mpc07005's Avatar
mpc07005
Sounds like a great time for a sixliter tuneup!
Old Jan 4, 2012 | 03:18 PM
OldGrayMare's Avatar
OldGrayMare
I Agree
Old Jan 4, 2012 | 07:49 PM
toby tough's Avatar
toby tough
You mite try puttin' some dielectric grease around the dist.cap where it sits on the base.That may help to keep any moisture from gettin' in there. Did that to mine cause I like drivin' thru big puddles.Used to stomp in 'em when I was a kid,now I drive thru 'em.
Old Jan 4, 2012 | 07:59 PM
Ole' gray's Avatar
Ole' gray
Guilty as charged
But havent had any symptoms from puddle jumping yet, seems to all come from the rain
Old Jan 5, 2012 | 04:28 PM
oldmongo's Avatar
oldmongo
When it runs bad is there visible water under the hood ? on the motor? .... Where did it come from ...front end, wheel wells? Next time just BEFORE it rains cover it all (electrical) over with W(water) D(dispersion) 40 and see if that changes anything ...it has bailed(no pun intended) me out before good luck!!!
I agree with the others ... this is a great time for a 6L tune up !!!
Thinlizzy13
17
Sep 29, 2017 06:52 AM
Jfrei
Nov 5, 2009 06:21 PM
64_f100_owner
Jan 11, 2004 04:15 PM
Bignorse
1978 - 1996 Big Bronco
Aug 21, 2003 10:17 AM
knocturnal
Jun 23, 2003 12:20 PM
