1/2 way thru my trip my trucks trip "A" went from a full display to a yellow box around it. Originally it was reset at the same time as trip B and the mpg display.
I've tried resetting just trip A and then all of the displays. Any ideas on how to fix this?
I've had the same thing. Can't remember which set of button presses brought it up, but when I 'discovered' it, I found it 'interesting' and therefore had to try it over and over to see if I had found some sort of 'easter egg'. Of course I also son't remember which series of buttons I pressed to make it go away. I'll try to replicate and get back to you.
I would second the pause comment. I did that once and didn't know what I did. Hit the button quick and it will un-pause. If that doesn't work, not sure.
I fixed the trip this morning. By pressing on/off with the OK button I was able to cycle trip a on and trip b off, then pressing again cycled them both on. I did "pause" the trip mileage from increasing, which I guess would be great if you needed to keep track of personal mileage vs company mileage as stated else where.
