Sensor Leak?
Old Jan 3, 2012 | 12:32 PM
Engalwood's Avatar
Engalwood
Sensor Leak?
Ok now I think I found a differnt leak on are 2000 F250. It appers this sensor is if looking under the hood is to the right towards the front if lookn stright at the motor. Top of the block to the right of the High Press Oil Line. It appers there is oil coming out of the connector part. I have no idea what this sensor is? Would anyone know what it would be called off the top of there head? Thanks again guys! I did notice it has a 3 prong wire connector on it if that helps any :/
Old Jan 3, 2012 | 01:08 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Sounds like the engine oil temperature sensor.
Old Jan 3, 2012 | 01:28 PM
Engalwood's Avatar
Engalwood
Thats AWSOME!!!!!! Thanks a bunch. Got her ordered. $13 a Ford Again, Thanks a bunch man!!!!!! Could this leak? Are would it just be the seal around it? When I took the plug out, i did notice oil in the top of the sensor? Just seemed kinda weird to me, but hope its it.
Old Jan 3, 2012 | 08:10 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Jan 9, 2012 | 08:53 AM
Engalwood's Avatar
Engalwood
Its the ICP sensore. Seems to have oil coming out the end of the sensor, like leaking threw the connector part not the o-ring at the bottom Found one for $135. Thats a lot to stop a oil leak for a LITTLE SENSOR :0
Old Jan 9, 2012 | 09:18 AM
tdpower's Avatar
tdpower
Where are you going to get the icp sensor from? There was a guy on ebay selling some that caused a lot of problems. I would get one from Ed or Clay in my signature.
Old Jan 9, 2012 | 10:09 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Here is an even better price.
Riffraff Diesel: Motorcraft ICP Sensor 97-03
Old Jan 9, 2012 | 10:22 AM
Engalwood's Avatar
Engalwood
Thanks, but just picked her up.... Be about the same after shipping Giggdy tho. Do these tend to leak threw the top of the sensor? Just makn sure im not seeing things HAHAHA
Old Jan 9, 2012 | 10:38 AM
honeydew's Avatar
honeydew
It is very common and the new one is a revised part to address that issue. I just replaced the original on my truck yesterday (thanks for the quick shipping Clay) since it was leaking a good bit of oil.
Old Jan 9, 2012 | 11:55 AM
Engalwood's Avatar
Engalwood
Yeah it suxs that its a freakn $130 Just to fix leak, even tho the sensor was still working to my knowledge :-)
Old Jan 9, 2012 | 12:00 PM
kawcrasher's Avatar
kawcrasher
It's not just fixing a leak, it was a warning the sensor is on it way out. That is a pretty important sensor on the 7.3, high readings from it and you don't run.
Old Jan 9, 2012 | 01:12 PM
Engalwood's Avatar
Engalwood
What excatly does it do? That I dont understand. Its on the top of the block on the front right side. All i saw was oil jsut ozzing out after i took it off to put new one in.
allhuntalltime
May 3, 2013 06:52 PM
bryanlindborg600
19
Jul 27, 2011 08:43 AM
meier63
Jan 25, 2011 07:32 PM
huronwoods
Nov 16, 2009 08:05 PM
StampedePSD
Dec 8, 2008 02:36 PM
