Wiper Problems
Old Jan 2, 2012 | 06:07 PM
allen23923's Avatar
allen23923
Wiper Problems
Ok im working on my father inlaws 1992 f150 it didnt have no low beam lights only high beam , i took the wiper - dimmer -turn signal switch apart and cleaned the contacts .Low beams work now but wipers will not turn off and washer pump is running even after i unplug the wires from switch it continues to run til i turn ign switch off .How is it running with switch unplugged ????? Ive taken it apart and cleaned everythiong and still the same
Old Jan 2, 2012 | 06:42 PM
Encho's Avatar
Encho
The Southernmost Mod
Replace the switch?.
Old Jan 2, 2012 | 06:57 PM
thechief66's Avatar
thechief66
X2
Common problem on these trucks.
Old Jan 2, 2012 | 07:06 PM
allen23923's Avatar
allen23923
Thanks Guys . I just wondered why it ran after i unplugged switch
Old Jan 2, 2012 | 07:41 PM
Encho's Avatar
Encho
Maybe when you cleaned it you created a bridge and it's shorting something inside, i hope you didn't put the part before you let it dry. Try a new switch, since it could be the easiest choice.
Old Jan 2, 2012 | 09:15 PM
FordOwnerJoey's Avatar
FordOwnerJoey
I got some wiper problems too. Ive replaced the switch and the motor, still the same thing, only works on high setting, no low or intermittent, my washerfluid pump doesnt work either (which sucks in salty road conditions because I have to stop frequently at gas stations to clean the windshield.
Old Jan 3, 2012 | 05:30 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Joey,
You need a new wiper speed governor for your 1987, or you need to open it up and solder the broken connections.
This is a black plastic 2.5" cube usually bolted to the top of the parking brake bracket.
The switch plugs into it, and it plugs into the harness under the dash.
Old Jan 3, 2012 | 02:17 PM
FordOwnerJoey
Originally Posted by ArdWrknTrk
Joey,
Ok thanks, I appreciate it!
Old Jan 3, 2012 | 02:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The screws that retain the mounting bracket also hold the housing closed.
Here's the heatsink that comes loose.
Old Jan 3, 2012 | 04:33 PM
Encho's Avatar
Encho
Check that the washerpump is connected, that's below the reservoir, if it's connected, check the little hose that goes to the windshield spray.
Old Jan 3, 2012 | 04:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You can usually hear the washer pump if it is working.
If it is, then the little nozzles in the cowl can be plugged, or the washer fluid has crystallized in the line.
I pin can clear the nozzles and an air hose can purge the lines back to the fluid reservoir.
If the motor is not working check for power to the plug when the **** is depressed.
I swapped my motor before realizing that the wires were broken where they enter the plug at the motor.
Old Jan 3, 2012 | 07:35 PM
Encho's Avatar
Encho
Well, my current issue is that the little hose broke, so that's yet another posibility.
Old Jan 3, 2012 | 07:43 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Where does it squirt out now?
Old Jan 3, 2012 | 09:04 PM
Encho's Avatar
Encho
Just half way, over the fender, the crappy plastic line broke right there.
Old Jan 4, 2012 | 12:42 PM
yardbird's Avatar
yardbird
When repairing the electrical govenor, DO NOT bolt it back down. Wrap it with foam rubber, put tape around the foam to hold it on, and just push it somewhere out of the way. The park brake releases very hard on these trucks. The controller is mounted just above the park brake rubber stop, and it will shake the insides of the controller apart after years of the brake pedal banging against the stop. Apply the brakes and release them and see how hard the pedal hits the stop. The whole dash will jump.
puppyf250
Apr 16, 2019 07:17 PM
wisner45
6.7L Power Stroke Diesel
Aug 3, 2015 10:35 AM
thegringo
Mar 2, 2011 10:56 PM
pdcheek
1997 - 2003 F150
Jul 13, 2004 07:12 PM
tiap
Electrical Systems/Wiring
Jan 23, 2004 05:40 PM
