6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Just found a puddle
Old Jan 2, 2012 | 04:01 PM
gernest2's Avatar
gernest2
Just found a puddle
So heres the issue... I was just leaving my sisters house when I noticed the puddle Its on the drivers side up towards the front of the truck close to the bumper. It's clearish and seems to have some sort of lubricant properties but no odor at all. My best guess would be either brake or power steering fluid. Any thoughts or better yet someone with the same issue? Its an 08 job 1. Thanks in advance
Old Jan 2, 2012 | 04:09 PM
Larry NCKS's Avatar
Larry NCKS
coolant leak? Maybe radiator hose o-rings?
Old Jan 2, 2012 | 04:21 PM
gernest2's Avatar
gernest2
Thats what my initial thought was too, but it doesn't have that sweet smell that coolant usually has...
Old Jan 2, 2012 | 05:10 PM
RoadJunkie's Avatar
RoadJunkie
Don't taste it!!! Does your sister have a big dog???
Just kidding...If there is no odor did you run defrost (or air conditioner)? Could just be condensation?
Old Jan 2, 2012 | 05:15 PM
gernest2's Avatar
gernest2
not unless it runs it automatically. had the climate controls in auto and it was a balmy 30F here all day
Old Jan 2, 2012 | 05:27 PM
ljutic ss's Avatar
ljutic ss
Keep an eye on your degas bottle over the next week and see if it drops. Does sound like a coolant problem.
Old Jan 2, 2012 | 05:58 PM
RM2738's Avatar
RM2738
That would be passenger side by the rear of the front wheel.
Old Jan 2, 2012 | 06:28 PM
senix's Avatar
senix
Coolant....be sure to check the fuel cooler as well as the degas bottle.
Look thru to the tow hooks and see if you see anything along the frame rails.
Look thru the drivers side front wheel well. You can see the egr coolers there. Alot of times if the upper radiator hose leaks it will drip down onto the coolers and you will notice the white splatter there.
May just need to get a flashlight and crawl under there to see it.
Be sure to not let the level get too low that it sucks air.
Old Jan 3, 2012 | 09:57 AM
hunter12's Avatar
hunter12
These trucks have had an issues with radiators. I had to have mine repaired.
I would describe the leak exactly as you described, front drivers side toward the bumper,
right above the frame, clear oily odorless liquid...
Do your due diligence and check hoses, orings etc, but odds are its a leaky radiator.
Maybe you could do a pressure test on it...
Old Jan 3, 2012 | 07:08 PM
gernest2's Avatar
gernest2
I found the leak today its my radiator... Anyone know if theres any recalls on the radiators themselves or just the o-rings? If not anyone have a better alternative to the $800 Ford OEM radiator?
Old Jan 3, 2012 | 07:14 PM
senix's Avatar
senix
no recalls
Don't know the costs but I hear good things about vista pro
Vista-Pro Online Parts Catalog#
Old Jan 4, 2012 | 09:34 AM
hunter12's Avatar
hunter12
Check with your local radiator shops, they may be able to repair it. ( your local Ford dealer likely will have a shop they use )
It is a seam on the radiator that separates. Mine was repaired with an
epoxy and seems to be holding up well. Only cost me $150
GreenMM
19
Sep 2, 2019 03:36 PM
cfietze
Jan 27, 2012 12:52 AM
Special Ed
Sep 28, 2011 07:42 PM
first truck
Jul 29, 2009 09:02 AM
rickytz7111
Jan 31, 2005 08:15 AM
