What does this mean.....Tech's please help !!
Old Jan 2, 2012 | 01:06 AM
King-bRanch's Avatar
King-bRanch
ok i swear i can hear an exhaust leak during "cold" starts & while trying to find it i saw this & it did it again today but i was prepared to record this video w/my phone...What do u guys think ??
BTW: i cant find a exhaust leak (by feeling around) but i swear i hear it
Oh...this is on the Drivers Side / Front Cylinder (#2) exhaust manifold
Cyc Froth.3g2 - YouTube
Old Jan 3, 2012 | 01:04 AM
dukie1877's Avatar
dukie1877
is there any way you can get some better light?
Old Jan 3, 2012 | 01:22 AM
King-bRanch
yeah i could but i thought by using the Flashlight it highlights the "Froth"
i didnt see anything out of the ordinary anywhere else & i dont see any coolant loss & truck runs fine
btw....as soon as manifold starts to get hot this disappears (a minute or so)
Old Jan 8, 2012 | 09:39 AM
King-bRanch
Nobody has any good ideas
Old Jan 8, 2012 | 09:43 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Tie a piece of string to a stick and hold it near where you suspect a leak...if there is one, the air will blow the string around.
Old Jan 8, 2012 | 10:13 AM
King-bRanch
Thanks steve but iam trying to find out what u all think about the "Frothing" that i seen at the manifold/head area (see video) while lookin for the leak.
What could cause it & how concerned i must be (cause iam now)...
Old Jan 8, 2012 | 11:19 AM
dukie1877's Avatar
dukie1877
I would think that is coolant. If it is coolant and its comming through your exhaust I would think it points tward a cracked head or a lifting head. Now dont freak out it is so hard to tell whats going on in your video on my screen. There is a few tests you can do to determine if im just full of crap. How does your degas bottle look? Coolant level ok? The only reason I dident post this last time is It really is tough to see whats happening and I dident want to freak you out for no reason.
Old Jan 8, 2012 | 11:24 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Gotta be a manifold leak and when it heats up the iron expands and seals the leak....the "froth"???? Without a sample, we are all guessing. I'd stick a test strip in the coolant tank.
Old Jan 9, 2012 | 12:08 AM
King-bRanch
A test strip for what & where do i get it
As far as DeGas bottle...What am i lookin for
The level is perfect now (almost on max) cause i just changed that thermostat & as far as i recall it was perfect level before that, now i did notice as very small amount of "white froth" in bottle around cap but hell you almost always see that in vehicles with DeGas bottles....
Old Jan 9, 2012 | 01:11 AM
dukie1877's Avatar
dukie1877
is it inside the cap or outside on the degas bottle? I think Bpofmd is reffering to test strips that test for exhaust in your coolant which would point to a head gasket problem. I am not sure where you would get those at but I would imagine they would have something like that at a autoparts store like Napa.
Old Jan 9, 2012 | 06:22 AM
bismic's Avatar
bismic
Lots of recent talk about this ............. It would identifiy a head problem (crack), a head gasket problem, or a bad EGR cooler. It would not distinguish which one.
06_KingRanch : I would check for coolant under the EGR valve.
Old Jan 10, 2012 | 12:43 PM
King-bRanch
ok pulled EGR & its dry as a bone & not even very dirty (looks new). I also checked in DeGas bottle again & aside from a very small amount on inside of cap i dont see anything in there alarming.
As far as exhaust leak goes ive had no luck finding anything except where my new exhaust system & catalitic converter bolt togeather (MBRP is sending me a new gasket free of charge) so maybe that sound is just traveling.
Another thing i noticed...after the truck has sat a couple days i looked for the "froth" again & actually noticed it comes out of Both sides of Front & Rear cylinders for just a minute or so (now it takes a minute after startup for it to happen).... Can it just be condensation
With my Gas'r engines during this time of year it will dump water out of exhaust tailpipe for a moment & since ive never seen the diesel do that maybe this is its way of getting rid of moisture (maybe all our trucks do it). Its just a thought since my truck runs great & iam hopeing theres NO head gasket issues
*I took some pics & will upload soon.......
Old Jan 10, 2012 | 12:48 PM
King-bRanch
Coolant Cap
Old Jan 10, 2012 | 01:08 PM
King-bRanch
EGR mounting location
EGR valve
Old Jan 10, 2012 | 02:17 PM
npccpartsman's Avatar
npccpartsman
The EGR/intake both look good but that crap on the inside of your Degas bottle cap looks BAD. Have you wiped it out with a paper towel to determine what it was? It almost looks like oil/water residue.
As far as the coolant level you posted earlier about being being at the "max" line, the level is actually correct at 1/2 to 3/4" BELOW the minimum line (unless your bottle has just one line). That isn't really a concern but you might have some pukage at some point due to overfilling but not necessarily because you have a real mechanical problem. I'm confused about the froth/bubbles in the bottle. I've never seen or had bubbles in my bottle even after running the dog snot out of my truck. The ONLY time I saw bubbles is after doing a simple green flush that took several flushes to remove and that wasn't from coolant.
I am very curious at this point about the bubbling manifolds.
