RCD vs SINISTER
Old Jan 1, 2012 | 08:01 PM
musclecars90's Avatar
musclecars90
RCD vs SINISTER
Alright so im starting my Stroker build I just ordered my ATS tranny Friday and now looking an getting studs, delete, etc. Now mkm and rcd has there own solutions kits for the 6.0. What are yalls opinions on each.
Old Jan 1, 2012 | 08:19 PM
BLADE35's Avatar
BLADE35
as far as an EGR Deleate I went with MKM/sinister egr deleate kit
everything fit Great
MKM shipped the same day I ordered it and got it in a timely manor
There are other egr deleate kits out there that are probably cheaper and would be Fine as well
I also changed all Gaskets Im anel that way but most are reusable if your careful
You will want a turbo hardware kit though the oil supply to the turbo needs to compress alittle to seal so best to just get that kit and replace them
Also get the upgraded HPO SS reservoir screen
Old Jan 1, 2012 | 09:16 PM
wgcdc's Avatar
wgcdc
I went with the RCD and I like it alot. I studied the RCD vs Sinister and I beieve they are basically the same. IMO, I like RCD becuase they are Power Stroke folks. I did use Sinister's instructions which are much better than RCD's
I had some trouble putting everything back together due to me being new, but Blade35 and several others helped me fix the problem. The thread is at this link:
https://www.ford-trucks.com/forums/1...gr-delete.html
Good luck with the install.
02GrayPowerStroke
Jul 6, 2017 06:57 AM
Fire85
Mar 20, 2012 10:57 PM
rcorcich
Mar 21, 2010 09:14 PM
dayooper
Oct 14, 2009 05:30 PM
