1978 - 1996 Big Bronco
Will not start
Old Jan 16, 2012 | 11:51 AM
  #76
joe f350's Avatar
joe f350
yea back in the vally i think the battery may have flat lined of is shallow charging what i would do it put a volt metter on the battery while its show 11 volts have some turn the key and i bet it will drop to zero
Old Jan 16, 2012 | 07:52 PM
  #77
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Had a friend try and jump start it today, and it started right up. So, it looks like I will be saving my pennies, and saving my dimes to buy a battery for this thing. Stuck a voltmeter on it, and it is only showing 10.5 volts now. Thanks for all the suggestions guys.
Jim
Old Jan 16, 2012 | 08:13 PM
  #78
GruesomeJeans's Avatar
GruesomeJeans
Thats great news! I would recommend the same battery i got but it isn't cheap... $240 later and i have a yellow top Optima battery with 750 CCamps so i don't think i will need one any time soon. Plus it's Gel cell so if i go wheeling and it somehow moves round i don't need to worry about spillage
Old Jan 16, 2012 | 08:19 PM
  #79
Nighteyez's Avatar
Nighteyez
Yeah, the local Autozone wants $189 for one of their optima batteries. I don't have that kind of cash, so I will have to get a cheaper one. The exact replacement for the one in the Bronco now is $123 with the tax added.
Jim
Old Jan 16, 2012 | 08:34 PM
  #80
GruesomeJeans
Yup they aren't cheap... I am happy with mine though, even if i don't use it to it's full extent.
Old Jan 16, 2012 | 10:17 PM
  #81
AzPete's Avatar
AzPete
The jump starting was recommended in the first reply....sometimes it is hard to get all the suggestions covered when they are mentioned, or the help to do it.....glad it worked and you can move on.
Old Jan 17, 2012 | 12:37 AM
  #82
Nighteyez's Avatar
Nighteyez
Yes it was, but I did not have that option available until today.
Jim
Old Jan 17, 2012 | 07:55 AM
  #83
AzPete's Avatar
AzPete
Jim
I realize that......it is hard enough to get someone to help when a person is in good health, and being laid up makes it that much harder. A lot of people would just wait for someone else.....you didn't....you pressed on looking for issues.
Old Jan 17, 2012 | 08:34 AM
  #84
joe f350's Avatar
joe f350
yea i new that was the problem have u checked the watter lvl in the batterys u might be able add some distilled watter and that might help till u can get a new battery
Old Jan 17, 2012 | 09:02 AM
  #85
Nighteyez's Avatar
Nighteyez
I checked and filled the water in the battery the day it would not start. Also tried making the cable connections tighter, but was unable to, which is why I bought the new cable clamps. Still no luck, and when I bypassed the solenoid, and got nothing, I decided to wait until I could get it jump started. Even though it is not fixed, I am happy now, because I know what needs to be replaced. Not knowing what the culprit was, was driving me crazy.
Az Yeah, this being partially disabled is a major pain in the bottom when it comes to working on the Bronco. It would probably be a different story if I was this way my entire life as I would not know what I was once capable of. Now, something as simple as crawling under the truck to check starter cable connections is impossible for me. Heck, even bending down to pick up a dropped socket is impossible. Good thing I have a "grabber" tool
Jim
Old Jan 17, 2012 | 04:05 PM
  #86
joe f350's Avatar
joe f350
East Penn/1 qt. battery acid/fluid (MCACID) | Battery Acid | AutoZone.com
here look in to this
Old Jan 17, 2012 | 08:20 PM
  #87
Nighteyez's Avatar
Nighteyez
I will pick that up this weekend (if it does not rain) after I get paid. If it works it will be cheaper than a new battery, and if not, only waster $4.31
Jim
Old Jan 17, 2012 | 08:28 PM
  #88
GruesomeJeans
Hopefully that will work
Old Jan 17, 2012 | 11:03 PM
  #89
Nighteyez's Avatar
Nighteyez
Yeah, a cheap fix would be nice about now, however, I never get that lucky...
Jim
Old Jan 17, 2012 | 11:21 PM
  #90
GruesomeJeans
Nah, these are cars we are talking about, a cheap fix usually never happens, and when it does it is only temporary
