1978 - 1996 Big Bronco
Will not start
Old Jan 10, 2012 | 07:53 PM
  #61
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Bypassed the solenoid, and got nothing, no spark, and the engine did not turn over.
Jim
Old Jan 10, 2012 | 08:02 PM
  #62
GruesomeJeans's Avatar
GruesomeJeans
Oh man that kinda sucks. I actually ran into this problem today but mine was the ground cable being funky. Have you looked at your ground cable for any melted holes? I don't know about the 93 but mine was bolted right under the alternator and must have rested on something to get it hot.
Old Jan 10, 2012 | 08:10 PM
  #63
Nighteyez's Avatar
Nighteyez
Well check that tomorrow.
Jim
Old Jan 10, 2012 | 08:43 PM
  #64
AzPete's Avatar
AzPete
You need to put a meter on the cables at the solenoid and see if power is there from the battery. Was the key to run when you did the solenoid?
Old Jan 10, 2012 | 09:06 PM
  #65
GruesomeJeans
I don't think the key has to be in order for it to cranks when you bypass does it? I know in 78 it didn't but i don't know about 93... Well all you can do Jim is test test test
Old Jan 10, 2012 | 09:25 PM
  #66
AzPete's Avatar
AzPete
Key does not have to be on to crank, just to start....but with the issues that are not working for him, I would also duplicate some tests with the key on and off....just in case.....
Old Jan 10, 2012 | 10:32 PM
  #67
GruesomeJeans
Ah i see what you mean
Old Jan 10, 2012 | 11:13 PM
  #68
Nighteyez's Avatar
Nighteyez
Okay, will try bypassing the solenoid with the key on tomorrow. Also, i want to check with test light, and voltmeter. However, IIRC I had 12v going to the solenoid, so maybe the issue is after the solenoid. Going to try to follow the cables, but I can't get under the truck. So I don't know how well that will go.
Jim
Old Jan 11, 2012 | 12:20 AM
  #69
GruesomeJeans
Ya sorry about the disability thing man, wish i lived closer then i could wiggle myself down there and help but i can't...
Old Jan 11, 2012 | 07:57 AM
  #70
Nighteyez's Avatar
Nighteyez
No big deal, I will figure something out. not like I have any money to pay for the gas to drive it, even if I do get it running.
Jim
Old Jan 11, 2012 | 09:32 PM
  #71
GruesomeJeans
Hahaha i hear that, I am almost on empty and have to wait till friday to get paid. I have money in savings but i try not to touch it as mush as possible
Old Jan 11, 2012 | 10:24 PM
  #72
Nighteyez's Avatar
Nighteyez
I have $30 worth of gas sitting in the Bronco now I can't use.
Jim
Old Jan 11, 2012 | 11:04 PM
  #73
GruesomeJeans
I have just above the empty line, i don't really know how accurate it is but it hasn't died yet so i just gotta survive a bit longer.
Old Jan 16, 2012 | 11:35 AM
  #74
joe f350's Avatar
joe f350
have u tried jumping it off a runing car i know that bettery is dead because i took the battery out of it and put it into my idi and nothing
Old Jan 16, 2012 | 11:47 AM
  #75
Nighteyez's Avatar
Nighteyez
No, still have not been able to do that. Maybe today, when Mike comes over, we can try jump starting it. Long time no see dude! Welcome back.
Jim
