91 f-150 5.0L
I'm stumped...changed my thermostat after it stuck open and replaced the faulty temperature sender. In doing so got coolant on the motor so decided to rinse off (thought I was careful and didn't soak the cap- rinsed mostly the block and intake around the water pump and thermostat). Tried to start it and had no fire. Thought no big deal and took distributor cap off to dry it and noticed it was in rough shape. Replaced the original cap and rotor with a new one. Left it off for the afternoon to get out any moisture. Still no fire. Tried the hairdryer and still no fire. Checked and dried the plug on the ignition module on the distributor and still no fire. Tried different coil wire with no luck.
Tried again today and still no fire.
It has to be from water getting in somewhere but usually a distributor would dry fairly quick, right? Any suggestions?
This is the perfect use for WD-40. Most likely you got some inside the ignition cap, near the coil or along the wires where they are older and breaking down.
Remove the cap and give the inside a light coat of WD-40, make sure you get the underneath side with the posts too. Re-install the cap and I bet she starts. You can also spray the topside of the cap, all of the boots and around the outside of the distributor. A little attention at the coil where the wire boots into it may be helpful too.
It's possible that the plug/connector for the distributor got a little water inside, may have damaged the PIP circuit when you powered up. Part 5 -Ford Ignition Module Test. Fender Mounted Module (ICM)....you could also check for codes, 14 I think is the PIP
Thanks slip ford man. It is very possible the connector got wet. I will try the test explained in the link and post what I find.
one quick dumb question...Is is possible to replace the stator without pulling the distributor? It it's just the ICM (and not the PIP) i believe can replace it without pulling it.
