1982 4.9l auto gas mileage?
#31
#33
on
Gasohol was invented in the '70s as an answer to the 1973 oil embargo and later the 1979 energy crisis. Mostly known by ethanol now.
So was EPA testing of MPG an "invent" of the 73/79 crisis.
My 1981 owners manual states that it is rated, and can use up to 10% Gasohol, but if any drivability problems to discontinue use.
The EPA testing was at 48 MPH on a dyno. This was supposed to be the average mean MPH that people drove. This was during the 55 mph legal limit imposed in the '70s. Again because of the 1973/1979 oil crisis'.
Why these trucks get their best mileage at 55 mph. How many people drive 55 mph let alone 48?
#34
I have a 1986 F150 with 4.9L and SROD with 3.08LS and 215/75 X 15 tires and drive like there is an egg between my shoe and the gas pedal. I have a 12 mile urban drive to and from work [many stop signs, traffic lights and then ~7 miles of farm land @ 45 mph]. I drive the same route with very consistent results and record my mileage.
It just so happens that I have the last 4 receipts in my wallet and they are as follows: 16.24, 17.16, 17.39 & 17.58 mpg.
On a recent somewhat hilly trip @ 55-60 MPH, it returned 22+ mpg.
I thought I might need to add that this is with Duraspark 2 ignition conversion and Carter YF from a 1970 F350. I should have mentioned that earlier. Sorry!
Last edited by 1986F150six; 08-24-2012 at 01:31 PM. Reason: Clarification re: Duraspark 2 ignition.
#36
on
The most mileage I've ever got was 24 MPG. This is completely flat driving at 55 MPH, and is not the normal driving conditions I usually drive. My friend with the same identicle configuration as my truck, except for a clark (tremec) 4-OD, claimed he got 28 MPG in the same trip.
This was before ethanol, "Gasohol" became the norm in gasoline though. Didn't say ethanol wouldn't reduce mileage, it will. Just meant to say it's been around alot longer than some people might realise.
Mine averages 18-21 MPG at the moment. 300-6, feedback carb, T-18, 2.75 gears.
I have noticed that the mileage can change drasticly depending on fill up, and retailer. Change 5 to 7 MPGs just because of a fill up, using the same brand of gasoline.
Wish pure quality gasoline was a sure thing at the pump. Even a guarentee of only 10% would be nice. I know some stations add more...
#37
#39
Those are still some outstanding gas mileage figures for the 300 though! 24 mpg and a claimed 28! Jesus.
You fellas got me wanting to go read about gasoline summer and winter "blends". I'm going to go do that.
#41
I have a '79 with a 4.9l. I put a 4spdOD in it. It has 2.75 gears and in overdrive I'm barely running the engine Driving 60-65 I got 18mpg. That was with the truck filled with boxes, helping someone move. Nothing too heavy though, normal stuff. I'm sure I can get 20mpg out of it . . but I want to see the math on the guys claiming upper 20s If I stayed at 55 ( can't do it ) . . maybe a couple more . . maybe.
#43
#44
#45
13: Ford 9" rear axle / 2.75-1 (1977/82) / No Limited Slip.
17: Ford 9" rear axle / 3.25-1 (1966/77) / 2.47-1 (1981/86) / No Limited Slip.
FoMoCo changed axle codes/ratios more often than women change their minds!
Tom92F150
03-01-2009 04:54 PM
