Check Engine Light Code PO455
Old Apr 17, 2003 | 09:08 PM
dsFord971's Avatar
dsFord971
"Check Engine Light Code PO455
Just had this code on my 97 Explorer.
The Description is
A large leak exists in the Evaporative Emission Control System
Does anybody have any ideas on where to start looking for this problem, if any?
The truck runs okay, only a slight rough idle after coming to a stop
Thanks,
Dave
Old Apr 18, 2003 | 05:53 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
is the gas cap on right ?
Old Apr 18, 2003 | 07:56 PM
dsFord971's Avatar
dsFord971
Yes, I replaced the gas cap with a new one from
Auto zone, goes on tight?
Any other ideas?
Dave
Old Apr 18, 2003 | 10:47 PM
Opera House Works's Avatar
Opera House Works
There is a charcoal canister and a vent solenoid. This valve is prone to rusting into the open position. If it looks bad, it probably is bad. Mine went on my 97. Valve is about $36 at dealer. Don't damage the plastic valve support, you won't get a new one with the valve. Testing: this valve is normally open and applying power to it will close it. Don't think it has an internal diode in it but test it with a brake lamp in series with the 12V just in case. Hoses come apart without any special tools though the mounting plate bolts will be prety rusted by now. Not too hard of a job. This is the primary suspect. If this checks ok then there is another valve under the hood.
Warren Hart
Sep 30, 2016 06:35 AM
japa11
1983 - 2012 Ranger & B-Series
May 5, 2015 09:17 PM
toddrochester
Oct 30, 2011 07:45 AM
lovs2fly
Oct 4, 2006 10:49 PM
jstang95
1997 - 2003 F150
Feb 21, 2005 09:24 PM
