460 start problem
Old Apr 17, 2003 | 07:39 PM
roughcreekgang's Avatar
roughcreekgang
Unhappy 460 start problem
I have this problem with my 88 F250, 360 FI. It has run fine for months. Then one day it would not start, just crank. Spark checked good. Fuel was pressurized (squirted out the valve on the fuel rail). If I press the gas pedal to the floor it will start(read in the manual later that this works when the engine is flooded), rev up and die. Did this several times. Then on the next try it started normally. Has done this several times now (in the driveway).
I replaced the fuel pressure regulator, pulled the injectors and had them serviced(they were pretty dirty, but not leaking or stuck). Replaced plugs and wires. The only code is 11. Still having the same problem.
Any suggestions greatly appreciated.
Thanks
Old Apr 18, 2003 | 03:47 AM
phantom429's Avatar
phantom429
460 start problem
This is just a guess but it sounds like it could be a bad map signal. Just a guess as it sounds like a few vehicles I have fixed in the past with identical problems.
Old Apr 18, 2003 | 11:53 AM
Just Strokin's Avatar
Just Strokin
460 start problem
Also check to see if the hose to the MAP sensor is good or maybe has a hole in it or rotten from heat or disconencted.
Old Apr 19, 2003 | 09:05 PM
roughcreekgang
460 start problem
Thanks for your input guys. Still no go.
Since last reply I have checked all vacuum lines and they are ok. I have replaced the MAP sensor and that did not help. I checked the fule pressure on the rail connection and get 40 lb with power on and that drops to 34-36 when cranking and to 32 when it starts. Consistently, so I think I can rule out fuel starvation. Spark is good. The only thing left that I can think of is the pulses to the igniters. I smell fuel when I press pedal to floor to start so think it is flooding, then when it starts it idles but if I try to rev up it dies. If the pulses are too long keeping the injectors open longer than they need to be and run very rich. What would cause that. I don't have a scope so can't verify this.
Any other suggestions appreciated.
I am committed to this now.
Can't take it to a mechanic at this point.
Well, back to the books.
Old Apr 20, 2003 | 04:07 AM
phantom429's Avatar
phantom429
460 start problem
What happens to fuel pressure when you step on it, and it dies?
Old Apr 21, 2003 | 02:52 PM
roughcreekgang
460 start problem
Fuel pressure remains the same as when running.
After it dies the pressure returns to 40.
Old Apr 22, 2003 | 02:32 AM
phantom429's Avatar
phantom429
460 start problem
Well, if the spark is for sure good, and fuel pressure is good, there must be a fuel control problem. For some reason it sounds like the injectors are not being fired properly. From where I am I can't help you as your problem is complex in nature. You basically need to do a total code scan KOEO and KOER. If these don't yeild any results you need to do a pin voltage test off of the PCM. Sorry I can't make it simple but unless you want to make more stabs in the dark at replacing parts this is the only way to properly diagnose this thing.
Good Luck
Penton97F150
1997 - 2003 F150
Jun 26, 2016 10:49 PM
MA Berlin
Apr 28, 2016 12:34 PM
johnvirgil
30
Dec 7, 2015 04:52 PM
steve.t
Feb 10, 2014 11:48 AM
blring
Jul 17, 2012 08:42 AM
