Coolant flush ?
Old Jan 1, 2012 | 11:21 PM
BLADE35's Avatar
BLADE35
Mine runs cooler to around town stop and go
But the true test is 60-65mph going steady on the freeway leval ground take the temps when it reaches the steady high temp
this time of year Im at 4-6 max spread at 65mph
but dead middle of summer it gets 6-8* spread
I did see a spread of 10* this summer but ambeint temp was 110-112*
But with an EGR deleate the spread isnt as important but I do watch it cuz a plugged oil cooler would still be Bad JUJU
Old Jan 1, 2012 | 11:33 PM
79 Stepside's Avatar
79 Stepside
Ok that buts me at the 20-22* delta then, not good news . Looks like I'm going to be flushing sooner then i hoped. Have to wait until Tuesday for dealer to open to get t-stat. Debating on to order coolant filter or make my own. Driveway is going to be a skating rink.
Old Jan 1, 2012 | 11:52 PM
BLADE35's Avatar
BLADE35
I made my own coolant filter I didnt like any of the kits out there
shure they look nice but they all reduce down to small return lines and like plumbing you can only flow as much as your smallest fitting allows
I kept all lines the same size and tyed back in at the heater return line (instead of the small line)
then I drill the Filter out in the middle where you see that plastic with the 5/32 hole I drill it to 1/2 inch
so the only thing that regulates the flow is the filter media but I change it fairly often for the first few
I bet Im filtering 2-3 times the amount of coolant as the kits do
heres some pics of what I did
the filter and bracket I made to hold it all
and then here is the return line kept it the same size as what I started with at the heater supply and droped it back in the heater return line under the coolant bottle
Old Jan 2, 2012 | 02:50 AM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Originally Posted by BLADE35
I beleive Im the 2nd owner got it at 36K
I changed the coolant and did a round of flushing VC-9 at 70500 added a coolant filter at this time to
didnt drive it much then so I let it filter for 2500 miles changed the coolant filter 2 times in that time
I was at 73K when I did the oil cooler another round of flushing with VC-9 and this time is when I undid all coolant lines everywhere and stuffed the hose in them and let it just flush with the hose for a few
It looked like casting sand to me as well and on that note I had a 25* spread at all times if I drove far enough to get it warmwd up to that point
also when I did 6the oil cooler I made the change over to ELC although I dont think coolant type is my problem
That's what I was after, if you thought it was casting sand or silicate goo. My truck has a 12-15 degree delta, getting ready to do a BPD EGR and new OEM OC. I flushed my truck at 20k when I did the ARP studs and HG's, and recently again at 42k.
I have a friends truck with 96k, never had the coolant flushed, getting ready to do it as well.... has a 30 degree spread! Curious to see what I find when I cut open both coolers.
Take care Bud.
Tim
Old Jan 2, 2012 | 03:03 PM
79 Stepside
BLADE35 Once again THANK U. Is the base from napa and filter a 4070. Also are those 1" x 1" x 3/4 " pex tee's. This is what I think I'm going to use.
Old Jan 2, 2012 | 07:25 PM
BLADE35's Avatar
BLADE35
yes base is a NAPA and filter is the NAPA 4070 uncharged
I got the hose from NAPA to 10 feet of it
and they are the PEX tee's I will have to go measure them but I think my coolant filter lines are the same size as the Heater Supply lines I tried to NOT Reduce anything
and Honestly I had about the same money into it as a premade kit 100.00-120.00
But I just didnt like how those kits reduce down so much tthought my odds would be better the more coolant I could filter faster
heres a cross referance for filters so whatever you like or can get cheap
COOLANT FILTERS
Fleetguard WF-2077
Baldwin B5134
John Deere RE11992
Caterpillar 9Y4528
Cummins 3300721
Wix 24070
NAPA 4070
NAPA 4069 (one inch shorter)
AC-Delco WF-108
Fram PR3383
Donaldson P554685
Alliance (Freightliner) WF2077
CarQuest 89070
Hasting WC8
Tommorro I will double check the size of PEX fittings and hose size
Old Jan 2, 2012 | 08:58 PM
79 Stepside
Great info. I appreciate all your help. Don't know when i'll be able to do the flush any time soon. But i'm kinda dredding it though. 50/50 chance if i can just flush or will have to do oil cooler & egr cooler. If so i'm going with BPD cooler kit. I'm hoping this w/e weather is soppose to get back up to the 40*. I have a heated garage but only have about 6" in front & back of truck . difficut to do anything to it. plus don't want the big mess.
Old Jan 2, 2012 | 09:23 PM
BLADE35's Avatar
BLADE35
Oh ya no doubt its a big mess and best in warmer weather
then you have to take into consideration that you may plug that oil cooler worse by stirring up all the junk inthere
But then on the flip side a blown egr cooler is a mess and a popped oil cooler is the worst case possible
heres some good ideas for flushing in this thread especialy if the oil cooler does plug
SOME GREAT IDEAS ON OIL COOLER BACKFLUSH
https://www.ford-trucks.com/forums/1...ch-advice.html
also if you have a round egr cooler that may buy you some time they are built better
Old Jan 15, 2012 | 08:23 PM
79 Stepside
We'll i did the coolant flush with vc-9. The first 5 gallons was alittle discolored . I flushed it for an hour and was as clear coming out as going in. Thought that might be good news . So i replaced t-stat, backflushed heater core. Added antifreeze ( zerox witch is clear I didn't care for that ) topped off . Drove highway flat ground about 50 miles , 65 mph. Delta was 18*-20* ( previous 20*-22* ) helped a little but still plugged. So i'm going to replace oil cooler and egr cooler. Thinking about BPD egr cooler (any suggestions), stc fitting ,icp pigtail, exhaust manifold gaskets (leaking alittle), glow plugs while i'm in there .Possibly BPD water pump. Up-graded turbo tube, & Coolant filter. Any other recommended up -grades while in this deep don't want to have to work on it for awhile Thanks.
Old Jan 15, 2012 | 08:37 PM
BLADE35's Avatar
BLADE35
Since you have an 05 do the standpipes and dummey plugs to
The Glowplugs in these seam good so you might could scratch that from the list
And if you dont scratch GP from the list add 2 GP harnesses cuz they will more than likely break. If your very very careful you might get them off without any damage to the GP harness
Ya those oil coolers are hard to flush out when they get clogged up the junk is just to caked in there
Old Jan 15, 2012 | 08:51 PM
79 Stepside
Ok added to list. Will be tearing down this spring just getting a list for now in town delta 9*-12*. Also is it normal to see alittle oil in the cold air tube from between the crankcase tube to the turbo and from the turbo to intercooler tube . Just a light film and alittle puddle in the hose on the outlet of the turbo where the hose fits over the turbo.
Old Jan 15, 2012 | 09:52 PM
BLADE35's Avatar
BLADE35
yes alittle oil in the air intake tubes and CAC tubes is normal. This is way some do the CCV reroute.
Do you have the square or round egr coolers??
And just keep in mind if your out of spec ECT vs EOT on the road test at the 65 mph the egr cooler is not getting the proper amount of coolant.
So regaurdless of weather or not your in town and the spread is within spec around town the egr cooler is still NOT getting the Proper flow of coolant. The egr cooler is still deprived of coolant. Your just not working the engine hard enough to drive the spread out of spec.
There is no test for the oil cooler for around town, around town is stop and go diffrent speeds Basicaly there are to many Varibles around town. this is why we test at Hwy speeds because there are less variables its more consistent and acurite of a test
but also keep in mind that 20* spread ECT vs EOT was the old spec
Now Im not shure but I think Ford bumped the max sread to 15* once all the square EGR coolers were Failing alot
Once it Failed the road test at a steady 60-65mph The oil cooler is plugged and has Failed the Test and is a Bad part.IMHO
Old Jan 16, 2012 | 12:33 PM
  #28
79 Stepside
Ok thanks. Is there a company that would sell all the listed items so I don't have to pay a ton in shipping from ordering from several company's. I really haven't had a change to search for parts yet. Hopfully I can tonight. Any recommended company's. Thanks
Old Jan 16, 2012 | 07:07 PM
  #29
BLADE35's Avatar
BLADE35
I would get all the OEM stuff from www.partsguyed.com
What you save on the oil cooler alone will be around 100.00+
and then get a egr deleate from whoever or a BPD egr cooler
Old Jan 16, 2012 | 09:18 PM
  #30
79 Stepside
[quote=BLADE35;11290451].
I have square. Sorry i can't seem to get this web site to copy . I thought it was interesting on standpipes . TECHNICAL BULLETIN APTB-03/08R1. Do you replace the standpipes and dummy plugs or just o-rings. By looking at this site I'm going to replace the sets. Also debating on delete or not. Whats the delta difference between delete or (BPD or stock) cooler.
