early 460EFI vs late 460EFI??
Old 12-30-2011, 11:02 PM
Iantiler's Avatar
Iantiler
Iantiler is offline
What is the difference between a 88-92 460EFI and later model 460EFI? Thanks.
Old 01-07-2012, 09:03 PM
Onyxdrake's Avatar
Onyxdrake
Onyxdrake is offline
Just did a swap from a 95 F450 into a 92 F250. Minor differences. Kept most of the 450 parts because research said the stock injectors, valves and throttle body were slightly larger. Overall slight stock horsepower difference, I think 10hp, nothing major. 450 engine also had a stock oil cooler that ties directly into the water cooling system. Thought that was a darn fine idea even though it's kind of clumsy looking, so I kept it. I'm pretty sure that was it for differences.
Old 01-07-2012, 10:43 PM
Iantiler's Avatar
Iantiler
Iantiler is offline
Thanks, I've dug through everything I could find.... not a lot of information to be found. I kinda remember the later models had slightly larger intake valves but wasn't sure about anything else.
I've bought a '89 F250 with a very tired 460, also have a complete '94 460 engine.... sounds like the '94 would be a better place to start.
Old 01-10-2012, 07:48 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
The heads changed in 93 with the F3TZ heads, There is apparently an intake change as there are 3 different ones listed E8TZ, F2TZ and F3TZ. The exhaust manifolds changed with the heads. The oil cooler you describe is a known leak point and was used starting in 90 on the 460s, prior to that they used an air to oil cooler in front of the AC condensor.
Old 01-11-2012, 10:44 AM
Iantiler's Avatar
Iantiler
Iantiler is offline
Thanks for the reply, some great information. I found a place in Indy called CFM that is suppose to do great port and polish work, been searching through old posts...... think I want a set of L&L headers also, seems to be the most recommended header.
Jimmy Dean
05-22-2014 02:07 PM
Onyxdrake
01-11-2012 07:00 PM
jayford
Large Truck
02-15-2011 09:29 PM
rhoward
11-12-2009 07:41 PM
79supercab4x4
05-24-2001 10:20 AM
Quick Reply: early 460EFI vs late 460EFI??
