Need Help Identifying a Relay
Old Dec 30, 2011 | 09:09 PM
79F150400M's Avatar
79F150400M
I have a 76 F-350 SCS....it was my Dad's truck, but he's famous for hacking stuff up. Case in point, the blower motor stopped working so he wired in a switch to turn it off and on. I found the plug he sliced into and it appears that some kind of relay is suppose to be in the socket. Anyone know the name of aforementioned relay?? Has 3 prongs. All I got is a Haynes manual for a schematic and near as i can tell its an accessory safety relay....
Old Dec 30, 2011 | 09:15 PM
HIO Silver's Avatar
HIO Silver
What are the wire color codes in said socket?
Old Dec 30, 2011 | 09:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If it's a Ford safety relay, it will have a ID number marked on it. Here are a couple of examples that apply to Super Camper Specials:
D2LY-14512-A .. Safety Relay-Use with Camper Package / Marked: D2LB-14C690-AA / D5AB-14C690-AA, BA, CA
D2SZ-14677-B .. Safety Relay-Use with Camper Package / Marked: D2SB-AA / D3AB-AA
If the ID number marked on the relay isn't one of the above, post what the number is.
Old Dec 30, 2011 | 11:43 PM
79FordBlake's Avatar
79FordBlake
Hmm are you possibly talking about the socket that plugs to the resistor that gives the different speeds of the blower motor?
Old Dec 31, 2011 | 01:24 PM
79F150400M's Avatar
79F150400M
I'll double check that.....but I'm pretty sure its not the resistor.
I'll have to go out and get the colors of the wires there HIO....
Thanks for those numbers ND....but I don't have the original.
Old Dec 31, 2011 | 01:31 PM
79F150400M's Avatar
79F150400M
Please Re-post
Originally Posted by bandtio24
Ihave a problem with my 1979 400-m engine starter. it makes a growling noise and acts like it is missing the flywheel. (new flywheel ringgear and starter).
Please re-post your thread with a title so you can get some answers. People wont see it since you posted under my title which has nothing to do with your problem. I don't think you have a relay issue. It sounds like its getting power to the starter. Growling noise.....check battery voltage.
Old Jan 1, 2012 | 07:50 PM
79F150400M's Avatar
79F150400M
I got the wire colors: Orange, Red W/black stripe and Yellow W/red stripe. Also confirmed its not the plug that goes to the resistor. That one is OK.
Old Jan 4, 2012 | 09:16 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Orange is key-on power for the blower switch
Red/Black is LOW
Where is the plug located? Behind the radio/ heater controls or under the hood?
Josh
Old Jan 5, 2012 | 12:08 AM
Daveyj's Avatar
Daveyj
my starter turns the motor over about two to three times then goes ziing. I put five starters on and they all do same thing new flywheel ring gear.can someone tell me the problem?
you should start a new thread with a descriptive title outside of this thread. You will get more help that way.
Old Jan 5, 2012 | 06:26 AM
Stinky7-11's Avatar
Stinky7-11
I have factory a/c in my 77 f250 and when my blower quit it turned out to be a 3prong relay screwed into the underside of the dash at the glove box, Napa had it in stock. not sure if thats any help.
Old Jan 5, 2012 | 09:14 AM
bandtio24's Avatar
bandtio24
1979 400M starter problem
My starter turns the motor two to three times making a growling noise then I try to start the engine again and it makes a zing noise and doesn't turn the motor. new ring gear on flywheel and have tried five starters and they all do the same thing.can someone help me?
Old Jan 5, 2012 | 09:29 AM
OldStyle's Avatar
OldStyle
Rusty Roller
You need help on a new topic. You will get help by starting your own thread/posting.
Start a NEW thread by "Clicking Here" See Picture below:
Old Jan 10, 2012 | 03:25 PM
79F150400M's Avatar
79F150400M
Yes....it helps a little. The plug is behind the glove box. Or at least ...it should be. I think NAPA will be on my list of errands today. Thanks for all your help.
Old Jan 10, 2012 | 08:41 PM
fmc400's Avatar
fmc400
MSEE
These trucks do not have a relay in the blower motor circuit. They go through the speed switch full on; that's why the switches wear out so fast. The speed switch adds in different taps of the blower motor resistor for all speeds below HI, for HI the switch is bypassed and the only thing in between the blower motor and fused power is the selector switch.
If someone actually did find a relay in their setup, please post a picture. It would be news to me (been wrong before plenty of times).
Old Jan 11, 2012 | 02:36 AM
Stinky7-11's Avatar
Stinky7-11
Well i had to check my title! yup 1977 f250 factory air, LOL
I do have a three prong relay in the blower circuit located under dash, it must be a factory relay seeing NAPA had a part number for it, it was ordered and when i hooked it up blower worked again. It's called an A/C Relay part # ECH AR235. blower does not work without it.
