catalyticconverter
Old Dec 30, 2011 | 05:11 PM
feth91's Avatar
feth91
Question catalyticconverter
my 04 f150 w/ 5.4l has a bad front passenger converter, i am not a mechanic or anything close so i need help. i took it to a mechanic and he said 230 to fix but another said 550. i looked at it and it is welded on, it is throwing the engine light on which tells me it is wired in. so could i just buy another, cut this one off and weld the new one in? any help is appreciated. . thanks.
Old Dec 30, 2011 | 05:59 PM
galaxie641's Avatar
galaxie641
Yes you can just put a new aftermarket cat in, they are less than $200 from Summitt or Jegs or the like. The light it is throwing is from the O2 sensors sniffing before and after the cat to make sure it is working.
Old Dec 31, 2011 | 10:41 PM
feth91's Avatar
feth91
Thanks. Now I just need someone to cut and weld for me
Old Jan 1, 2012 | 08:54 AM
projectSHO89's Avatar
projectSHO89
Go back to your previous post and edit out your phone number...
Why do you think you need a new converter? This sentence fragment, "it is throwing the engine light on which tells me it is wired in." makes absolutely no sense at all.
Old Jan 3, 2012 | 06:41 AM
phil6608's Avatar
phil6608
I have to agree with the post above me.
The light for a cat dose not necessarily mean you have a bad cat!
How many miles are on the truck?
What is the actual code # ?
Old Jan 9, 2012 | 09:20 PM
feth91's Avatar
feth91
i took it to a mechanic back home, they told me the converter is rattling, and it is causing back pressure. one of my pistons ( if im remembering correctly) is starting to slap bcs of the back pressure. i apologize if i state anything wrong, i am no mechanic and dont know much as far as trucks go. thanks once again
Brad Brown
Dec 2, 2017 03:03 PM
spic21
1997 - 2003 F150
Dec 21, 2012 12:31 PM
Pro DIY
Jun 28, 2010 10:30 AM
Tired_Escape_Driver
Escape & Escape Hybrid
Jan 25, 2007 09:41 PM
southprk
Oct 11, 2003 07:40 AM
