tach install?
Old Dec 29, 2011 | 10:35 PM
CMMC's Avatar
CMMC
tach install?
Hi guys. My ranger has the simpler trim package w/o the tach. I am a big fan of knowing what the motor is doing at all times as i live in a very hilly area of MT. I have put tachs on rigs before but have never really had to play the the D.I.S that is underhood my 2.3l. Is there a wire that you can use as a signal wire or should i invest in an inductive tach?
ps. what your rangers run (rpm) out on the Highway? (Mine is a 5sp)
Old Dec 30, 2011 | 02:53 AM
michigan66's Avatar
michigan66
What gear ratio does the rear axle have?
Old Dec 30, 2011 | 09:14 AM
CMMC's Avatar
CMMC
I'm not sure what the ratio is. Is there a tag that tells you or is it stamped on the ring gear?
Old Dec 30, 2011 | 10:46 AM
KhanTyranitar's Avatar
KhanTyranitar
Use the Tan/Yellow IDM wire as your tach, it may already have a single plug for just such a purpose, otherwise you have to fine it. Some years may use different colors, so it may not be tan/yellow on yours.
Old Dec 31, 2011 | 10:28 AM
casper tim's Avatar
casper tim
how do hook up a after market tach on my 7.3 its a idi engine1988 ford 350
Old Dec 31, 2011 | 03:33 PM
michigan66's Avatar
michigan66
There is a tag held on by one of the differential cover bolts that will give you the axle ratio information.
Old Jan 1, 2012 | 12:05 AM
CMMC's Avatar
CMMC
ill check that tag out that would be nice to know. However i took the truck out on the highway today for the first time with my scan tool hooked up to it. I am not sure if i need to worry about the rpms its only running about 2500 in fourth at 55 mph and 2300 in fifth at 65 and that is only able to happen on a straight with the wind behind me. For the terrain that i live in its going to need more hp or tq to get out on the road much any thoughts on that?
Old Jan 24, 2012 | 02:55 PM
xxshine's Avatar
xxshine
Inductive won't give engine R.P.M. for cases of tuning E.T.C. As for hooking up tach question - try Autometer digital tach. They are available il different sizes.
Old Jan 24, 2012 | 10:53 PM
michigan66's Avatar
michigan66
My '91 Ranger had the same kind of RPM numbers you have and it had a 3.45 rear end ratio.
Old Jan 25, 2012 | 06:58 AM
piotrsko's Avatar
piotrsko
you didn't say what year and I'm only good on the years listed below, but: find a dash in the wreckers that has the stuff you want. the parts interchange except sometimes the wires are missing in the harness. I picked and chose on my ranger from one of the parts rangers I had until I got a full compliment of gauges instead of idiot lights. You'll need a good wiring diagram. Have fun and remember no truly custom mod is a slam dunk.
Old Hickory
Feb 26, 2011 08:39 AM
4DS4EVR
Jun 5, 2008 07:07 PM
jws2fly
Feb 5, 2005 09:20 PM
kikr1388
Jan 20, 2005 08:17 PM
123svt
Nov 22, 2004 11:03 AM
