Codes and EGR Questions
Old Dec 31, 2011 | 09:55 AM
SleeprLegend's Avatar
SleeprLegend
Originally Posted by danr1
Idle speed is 100% computer controlled and is not adjustable, there is a stop screw on the throttle body yea however it is factory set and never needs further adjustment.
Should be sealed/locked in place, if its been tampered with yea you'll probably need some help resetting it to its proper set.
If it is locked/sealed in place and has never been tampered with, please do not mess with it it is not an idle adjustment screw.
It's set to allow butterfly plates to fully close but without digging into the throttle body.
I can see that the screw has been adjusted by examining the thread locker on the screw. What are the steps for properly adjusting it?
Old Dec 31, 2011 | 02:32 PM
danr1's Avatar
danr1
This should suffice get ya back where you need to be,
1983 Ford Bronco Diagrams picture | SuperMotors.net
Old Dec 31, 2011 | 03:19 PM
SleeprLegend
Thank You!
Old Jan 12, 2012 | 03:13 PM
SleeprLegend
I found a broken vacuum line and a cracked vacuum cap. After fixing those the only code left was the throttle position sensor. I looked at the adjustment screw and noticed it was screwed in. With the engine running I slowly screwed it back out and the engine almost stalled and came back to life. I ran the tests again and I have no codes!
Thank you all so much!
Old Jan 12, 2012 | 09:41 PM
muscletruck7379's Avatar
muscletruck7379
glad it worked out!
BRay09
Mar 4, 2012 11:21 AM
griswold
Aug 11, 2007 12:23 AM
arch-nemesis
1978 - 1996 Big Bronco
Sep 18, 2004 05:59 PM
dbuck50
25
Aug 16, 2003 02:17 PM
dan_da_mick
Apr 15, 2002 10:04 AM
