motor swop?
Old Apr 17, 2003 | 03:27 PM
nigel6950's Avatar
nigel6950
motor swop?
Does one need to make changes to install a 1996 351w long block in a 1992 f250 that originally came with a 351w?
Also what changes are needed to go from an automatic to a manual?
Old Apr 18, 2003 | 01:34 AM
steve83's Avatar
steve83
motor swop?
The long block should be a direct replacement, as long as you're using the '92 manifolds, wiring, & computer.
To go to manual, you'll need the aluminum pedal bracket, a new ($17@Ford) upper steering column shroud (for when you remove the shifter), a hydraulic clutch system (don't mix parts), flywheel & clutch, & crossmember. Also, you'll have to have your driveshafts cut for length. Go to http://www.broncodata.com/ and contact the webmaster - he recently swapped his E4OD for an M5OD in a '93 Bronco.
oldschool_77
Jul 15, 2010 11:12 PM
minicanes
Engine Swaps
Nov 20, 2004 04:15 PM
jsslasj
May 26, 2004 08:12 AM
88bronco351
1978 - 1996 Big Bronco
Dec 11, 2002 10:09 PM
rc351w
Mar 22, 2001 10:44 AM
