351w Rear Main?
Old May 24, 2004 | 07:36 AM
jsslasj's Avatar
jsslasj
Question 351w Rear Main?
How easy is it to change a rear main seal on 351w in a 1984 f150 4X4, and what is the best way to change it!?
Old May 24, 2004 | 04:42 PM
RTM's Avatar
RTM
I believe the 84 351W motor has the one piece rear seal and if so then it's easy to replace once you pull the trans or the motor.
Old May 24, 2004 | 06:34 PM
jwtaylor's Avatar
jwtaylor
Its real easy to change but it will take you for ever to do it.
Like RTM mentioned you should have a one piece. You have to unbolt the tranny, slide it back, take the flywheel or flexplate (depending on your tranny) off and then the fun part, you will need a punch, punch two holes into the seal on opposing sides, screw two machine screws into the holes take a piece of wire or strong string and use something to pop the seal out, breaker bar or whatever you feel will work, lightly tap the new seal in making sure its straight...very easy procedure, but its time consuming. I would recommend you go get a haynes repair manual for 80-96 ford trucks, at any autoparts store, it goes over this procedure, more importantly it describes and explains many procedure that you may eventually have to do to your truck. Good luck
Old May 26, 2004 | 08:12 AM
jsslasj's Avatar
jsslasj
Thanks alot for the info RTM and jwtaylor, I will get that manuel and get to work!
nuknuk
Sep 8, 2016 05:37 PM
77FordSteve
Feb 29, 2016 04:49 PM
ItsAFord55
Dec 8, 2015 11:30 PM
derbydad276
WTB - Parts & other
Jul 11, 2014 10:33 PM
Millenium Edition
Apr 14, 2012 09:24 PM
