Help needed with Code P1280
Old Dec 29, 2011 | 08:19 AM
brenthottle's Avatar
brenthottle
My uncle has a 02 350 with the 7.3 diesel on it. He said when he first starts to drive his truck the check engine light comes on but after a few miles it goes off. He checked it while the light was on and it came up with the code P1280. He said the truck runs fine even when the light comes on. Were curious as to what this means and what needs to be done to fix the problem! Thanks
Old Dec 29, 2011 | 08:51 AM
mueckster's Avatar
mueckster
He may have the indications of an ICP sensor going bad. Remove the plug on the ICP sensor and check for oil leaking from the sensor terminals. If oil is found, replace the sensor and clean the plug before installing. This is the most common cause of a ICP code glitch.
Headviking
2009 - 2014 F150
Apr 1, 2019 01:39 PM
fseries01
1997 - 2003 F150
Jan 2, 2009 07:31 PM
mybigredford
Jun 17, 2008 12:07 PM
keyul
1997 - 2003 F150
Nov 30, 2007 11:12 AM
slowfour
Oct 13, 2006 10:13 AM
