MIL Light Eliminator
Old Oct 10, 2006 | 08:34 AM
slowfour's Avatar
slowfour
FYI - I installed a home made MIL light eliminator (instructions found on WEB) but after 4 restarts and drives the CEL came back on. Guess I either live with the light being on or look for a pricey converter replacement.
Old Oct 10, 2006 | 04:33 PM
projectSHO89's Avatar
projectSHO89
And did you re-read the fault code?
What was your original fault code?
steve
Old Oct 11, 2006 | 06:15 PM
01silvergt's Avatar
01silvergt
MIL's only work if you have an operational O2 sensor. If you have a bad sensor they will not work.
I agree with the poster above, what is your current code, what was your past code? Might be that you just need to replace the sensor.
Old Oct 13, 2006 | 03:05 AM
slowfour's Avatar
slowfour
Original code was 0420, worn out cat. Pulled O2 sensor and ran the bench check using a propane torch and the voltage seemed OK. Haven't checked to find out out what the new code is with the MIL eliminator installed. Need to make a trip to Autozone.
Old Oct 13, 2006 | 10:13 AM
01silvergt's Avatar
01silvergt
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Yeah, that code normally indicates a bad cat. Your MIL should work just fine if you have a good O2 sensor. Where did you get your MIL? What is the new code?
07expeblack
Jun 7, 2012 08:08 PM
CrumpDogg
17
May 22, 2012 03:19 PM
fiftyfordfloored
1997 - 2003 F150
Oct 21, 2011 10:24 AM
cadillacmob
Mar 20, 2010 05:06 PM
mwh
2004 - 2008 F150
Sep 7, 2004 08:32 PM
