DP Tuner "Decel" question
Also make sure you have the full ten pounds spring pressure on the EBPV. thats how you set it up after rebuild. I'm not sure this will keep it from getting stuck but at least you know it is set up right. My decel has never worked on my e99. And I know others who have had this problem. I think its the PCM tuning on the early 99.
Chet
Chet
I am actually in beautiful SC myself, for a couple of weeks of leave. Got home a few days ago.
I'm glad you are enjoying Hunting Island, it's a nice park. I love how it is removed from the hustle and bustle of Myrtle Beach, but close enough to drive up there if you want.
Have fun!
Chet
Armed with new information in this thread, I came home from camping in South Carolina via Asheville, NC and Newport, TN (much colder on 1/1/2012 than during RRE).
I wanted to see how I pulled the steep grade on the South Carolina/North Carolina border. Pulled great. I had to slow down due to increasing Exhaust temps, but got to the top of the switchback at 45 MPH with plenty of power.
I think that I have been swithing from DECEL to TOW too quickly. I have probably been trying to accelerate before the EBPV was fully opened. I switched it off and "listened" for the change in sound and then counted to 5 before giving fuel. It worked very well.
Thanks for the lessons and the input.
Hey Bob, glad you got to take a break. Sorry that you have to go back.
Chet
Chet
So I got ahold of James at DP and this is what he told me in his email.
" If you are going to do one of our chips then there is absolutely no need to change the pcm from early 99 to NVK unless you just want to. There is ZERO performance difference with our chip on an early 99 XLE code or on a 2000 NVK code.
This is a misunderstanding on the forums and does carry some validity but not with our chips.
Most all other programmers cannot tune the early 99 pcms because they cannot change them like the NVK or PMT. We have the ability to basically take a NVK or PMT tune and put it on a XLE early 99 pcm so you don’t have to buy a new pcm. We can modify the XLE to be exactly like a NVK or PMT is what I mean."
And with that said maybe it's just needed to be flashed with a NVK or PMT tune. I don't know to be honest?!? The more I learn about the e99 pcm issues or non issues the less I know.
But to get back on subject I love the " DECEL Tune" and that is one of reasons I too am going to go with DP over other tunes out there. When I have $$$ to get tunes I'm getting DP. It is killing me having stock XLE tune.
And after going back and forth on keeping the ebpv or getting rid of it. This tread has me convinced of 2 things.
1: I am keeping the ebpv system
2: I am going to go thru and rebuild my ebpv and make sure it only takes 10lbs of force to open the valve. So that down the road I know it set up right and everything is working. May as well the truck apart right now
My only question is how do you check the electric switch/valve on your pedestal ? Do you check with omns, low voltage or 12volts to see if it working without having it plugged into the wiring harness or pcm ? I want to bench test it.
Hello Chet I have heard alot of different people say there was problems with e99 pcm XLE4 and their tunes.
