I NEED help
Old Dec 28, 2011 | 11:33 AM
79half-ton's Avatar
79half-ton
I NEED help
Alright guys, I just bought an 88' F150 4x4 4.9(300) 5 speed and I messed it up pretty bad. When I bought it it had a timing issue, when I looked at the wires on the distributor I thought they were in the wrong place so I took them off to put them in the right spots, I looked in my chiltons manual and found the firing order. Well not she won't start, she seems like she wants to turn but then she backfires. My dad says that she is out of time and that I need to set it but I can't find any place that tells me how to time the distributor. I'm at a loss and need some help please
Old Dec 28, 2011 | 11:52 AM
ctubutis's Avatar
ctubutis
Why don't you just put the wires back how they were? Maybe somebody changed the cam at one time and changed the firing order.
You're aware that the rotor turns counter-clockwise, right?
If it is still factory, the ignition timing is controlled by the computer, about the only thing you can do is disconnect the SPOUT connector and set the initial timing (to around 10° IIRC) and the computer handles everything from there.
Old Dec 28, 2011 | 12:53 PM
Cheggie's Avatar
Cheggie
Spend some more time with the firing order. You more than likely have the wires out of order - can't tell you how many people do this. Don't adjust anything else until you've corrected the firing order, and it runs like it did before you removed anything. Study the book carefully, set the engine to TDC, and make sure you start with # 1 wire on the distributor cap tower where the rotor is pointing.
Old Dec 28, 2011 | 01:14 PM
ctubutis's Avatar
ctubutis
I agree with Cheggie - put it back the way it was before trying to adjust anything.
Old Dec 28, 2011 | 09:46 PM
88n94's Avatar
88n94
I was thinking that also. My Haynes manual shows the rotor turning clockwise.
Old Dec 28, 2011 | 09:58 PM
ctubutis's Avatar
ctubutis
Looking more closely, I think I'm wrong on that and you're right - I'm used to V8 engines, I guess.
According to what I've found on the 'net, the dizzy in these engines turns clockwise as the Haynes manual apparently says.
1-5-3-6-2-4
Old Dec 28, 2011 | 10:03 PM
88n94's Avatar
88n94
A very pertinent question: HOW OLD IS YOUR CHILTONS MANUAL? The firing order did not change, but on the 1987 and later engines the cylinder numbers change on the distributor cap in RELATION to the clips or hold down screws on the distributor cap.
Old Dec 28, 2011 | 10:20 PM
88n94's Avatar
88n94
To 79 half-ton: The sketch that ctubutis posted under NO.6 is correct for 87 and later engines. ie the relation of the clips or hold down screws in relation to the plug wire numbers. Just in case your Chiltons manual shows different.
Old Dec 28, 2011 | 10:51 PM
79half-ton's Avatar
79half-ton
I can't thank you guys enough for the help, I just picked up the manual since I just bought the truck and it is the same as ctubutis post, I'm used to v8 as well I also have a 79 f150 with a 351 and that's hat I am used to. But after working all day on it my dad and I got her running. Thanks again guys
Old Dec 29, 2011 | 12:28 PM
Cheggie's Avatar
Cheggie
One more thing for this topic - if you have the gray distributor cap, do yourself a favor and mark the towers with a black permanent marker. If you ever need to remove the wires again, it makes your life so simple!
I also mark the distributor to block orientation with the marker, but mine is recently clean and resealed - oily engines may not get away with that!
Dalton Hampton
Dec 5, 2019 09:25 PM
Gans
Jul 23, 2011 06:07 PM
montgomery7
23
Mar 1, 2010 07:53 PM
garreth
Feb 25, 2004 09:19 AM
dutchmen
May 22, 2003 01:27 PM
