OT? Ford 9"
Old Dec 29, 2011 | 10:36 AM
brain75's Avatar
brain75
Originally Posted by Moe Craig
Well I'm suppost to have the 4.11 in my 9", but behind the th350 and I have to either change my transmission (to a 700R4) or the gearing as I can't go onto the freeway that well...
Moe, I didn't research the Chevy stuff that heavy so I had to look yours up - automatic right... Well I have no advice for a good final ratio that is torque converter friendly - didn't do any research at all on automatics.
One thing I would say is that is one super super close ratio 1st is ~2.5 and 3rd is 1.00. If you are wanting freeway speeds and the ability to start from a dead start you have to have a larger range than that. I'd be looking at a trans swap.
Old Dec 29, 2011 | 11:30 AM
HD74's Avatar
HD74
I found a 1970's 9 inch with a 3.50 gear that i rebuilt with a Detroit locker and kept the 3.50 gear. Now after driving around the front range. I should have opted for 3.70 gearing. Around town and on the flats 65 mph and faster no problem, but when it comes to hills I wish I had the 3.70. My T19 has the same gear ratio as the T5 minus 5th gear. I would't put anything higher than 3.50.
Old Dec 30, 2011 | 01:52 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
The big thing none of you mentioned is rear tire size, the OD of the tire plays a big part in figuring out your overall ratio which in turn effects rpm's. Here is a great tool for figuring out what your final ratio/ rpm's will be.
http://www.f-body.org/gears/
Bryan, when talking about rear axle ratios lower gears are a higher numerical ratio, you had it backward "understand the lower the gear the higher the top end". For example a 4.11 is lower than a 3.50 gear and thus could lower your top speed if your engine can't get the rpm's needed.
Hope this info and the site helps.
RJP66F100
May 5, 2011 02:37 PM
Whiskey Bent
Aug 20, 2009 06:43 AM
junkyarddog82
Feb 6, 2008 11:13 PM
79Ford460
Apr 18, 2004 10:35 AM
superswamper
26
Apr 25, 2003 05:20 AM
