i have a 76 f100 with the 9" rear, i was wondering if there is an easy way to tell if i have 28 or 31 spline axles, and how much would the 28 spline carrier work with a 31 spline mini spool?
Whoa! No need to take anything apart! There is an easier way to check which axles you have. There are 10 bolts holding the carrier in the axle housing. One of these bolts will have a small metal tag attached to it. The bottom row of numbers on the tag will give you 2 pieces of information. For example mine says:
3L50 9 S319B
The first number tells me that my "chunk" is equipped with 3.50 gears. Ford used an "L" to replace the decimal point I assume to make it easier to read. The S31 in the last number means it has 31 spline axles. Hope this helps!
P.S. I wouldn't use a spool if you drive on the street, especially if you are running big tires. When you go around a curve the outer wheel is traveling faster than the inner wheel. If the differential can't unlock to allow the wheels to turn at different speeds, one wheel will slip or something will break. Usually the latter.
Originally posted by jeffh31 P.S. I wouldn't use a spool if you drive on the street, especially if you are running big tires. When you go around a curve the outer wheel is traveling faster than the inner wheel. If the differential can't unlock to allow the wheels to turn at different speeds, one wheel will slip or something will break. Usually the latter.
Welcome to FTE!
Just out of curosity, do you have or have you ever had a spool or mini-spool in your own truck? I've been running a mini-spool in mine with 33s for over a year and have had no problems. I just put on 36s and am still having no problems.
I'm sure some people have had problems, but there a few others on this site that have been running them for years in their daily driver trucks and had no problems. Not even noticible tire wear.
Again, the beauty of the mini-spool is that it's cheap and easily removed.
A solid axle setup is plain dangerous if you live in ice country. Don't run a spool on the street, it is a major nono, just ask any of the diff shops. Use a lim slip etc if you must, but even then it can be a hazard on ice or snowpack. Just because it is "working" doesn't mean it is right or safe.
Jeff, I have to dispute that about the S31 meaning 31 spine axle.
That number to the righr of the ratio code has always been Plant code.
It is the Bearing code ie WFE-BK2 that states what bearing is in it and thus will reveal ina Ford book what the axle spline is.
The factory or plant code is a every tag item,whereas, tha spline codse isn't.
See Below.
Ford changed the layout of the tags sometime in the early 70's or late 60's, here is a WFE-BK2 tag, followed by a date code of 4E24 (April 24,1974), the second line now gives besides the ratio-here a 3L50, the ring gear actually used inside-this one is a true 9" gear.This tag is off a 74 Ford truck.
Originally posted by Torque1st A solid axle setup is plain dangerous if you live in ice country. Don't run a spool on the street, it is a major nono, just ask any of the diff shops. Use a lim slip etc if you must, but even then it can be a hazard on ice or snowpack. Just because it is "working" doesn't mean it is right or safe.
Driving ANYTHING on ice is dangerous. 1, 2, or 4wd won't make any difference, Ice is ice. Unless you're running studded or spiked tires, that is.
True, cornering in snow will be drastically different with a spool than with an open dif.. But if it's slippery, LS or a locker will act like a spool. There won't be enough torque on the wheels to break the clucthes/locker free. Even with an open dif, a rear wheel drive pick-up with no weight in the bed is gonna corner like it has a spool in it anyway.
You're right about "just because it's working...". However, just because you might run into problems several years down the road doesn't make it wrong or unsafe.
I've spent my entire life in Wisconsin and have been driving here for almost 20 years. I've driven virtually every type of vehicle in almost every type of weather. The vehicle you drive is much less of a factor in safety as the way you drive it.
I have just put a mini-spool in my 9" with the only difference being that my axles are 28 spline. There is no reason that a 28 spline carrier won't work with a 31 spline spool and axles. The only difference in a 31 and a 28 is that the spider gears are for either a 28 or 31 spline axle. I say go for it and if it breaks, FIX IT. As with any performance modification, everyone you talk to will have an opinion as to wheather it is good or bad.
I have been worng many times before and will be wrong more times in my life so here goes. When putting in a mini spool you are doing away with all the internals such as spider and bevel gears. So are you saying that a 31 spline axle is so big that it would not fit through the axle tube??? I think that what he wants to do will work just fine. But mabey not.
Im contemplating the same thing,
I just cant afford a locker or what have you, so ive decided to get a mini spool for my 9''. I also am not sure whether tis a 28 or 31. I guess i might as well jus take 'er out an look eh?
Padd77 says spool for 31spline will work with 28 aswell, but Bullitt says nay, And my tag is also not there.
Ill giver a whirl.
