honing a 351m
Old Dec 28, 2011 | 08:09 AM
jackdaniels250's Avatar
jackdaniels250
honing a 351m
I have a 351m that i just stripped down yesterday. evrything seems to be in good shape but the cylinders could definitly be honed. Im wondering what type of hone i should use and grid? thanks
Old Dec 28, 2011 | 08:43 AM
mark a.'s Avatar
mark a.
If you just want to break the glaze and don't care how much out of round or taper is in it then use a ball hone, those spring loaded hones do more damage than good. The grit would depend on the type of rings you are going to use.
Old Dec 28, 2011 | 10:51 PM
wyoming4x4's Avatar
wyoming4x4
ball hone!
like mark said ball hone, yes. deglaze cylinder light scuff. the next step is to measure cylinder and compare to piston on clearance. check ring end gaps and assemble if everything is decent. good luck. best way is to torque plate hone the cylinders. the tops move around a lot near head studs/bolts. torque plate hone help simulate a torqued head to block and get better measurements and actual round cylinder with less deviations down the cylinder especially at the top. good luck.
Old Dec 28, 2011 | 11:06 PM
planehunter's Avatar
planehunter
X2 on all said.
pineconeford
19
Apr 19, 2016 07:33 AM
460man
Mar 7, 2007 06:25 PM
bigbrown84truck
Apr 10, 2006 02:16 AM
hanabi
Sep 22, 2004 07:10 AM
oleblue70
Jan 16, 2000 08:46 PM
